01-30-2023, 04:15 PM
Brakes not working. Controller OK
2018 T21TBHW (same as Rockwood A122)
2018 Kia Sorento 6cyl AWD
Brakes not activating.
The brake controller in the tow vehicle checks out OK.
All brake lights are working.
Power is going from the tow vehicle to the brakes.
BUT, the controller is not showing that the trailer is connected.
Is there a fuse in the trailer side to check out? If so, where would it be?
Other possibilities?
Many thanks!
Bruce
2023 Geo Pro 19FD
01-30-2023, 04:27 PM
What kind of controller?
Factory integrated or aftermarket add on?
01-30-2023, 04:29 PM
Add on. Tekonsha Pilot. Used to work fine.
2023 Geo Pro 19FD
01-30-2023, 05:15 PM
Many thanks!
Bruce
When I suspect a problem like you describe there are two steps I take:
Make sure the 7-pin connector to the trailer has clean contacts. Often the plug is exposed to the elements and can get enough dirt/corrosion on the contacts to prevent enough current (3 amps per brake magnet) to activate the brakes.
I then pull the emergency break-away pin and measure the current with a clamp type DC ammeter my multimeter has built in. Not expensive on Amazon. Since I have two axles w/4 brakes total I look for 12 amp or real close. If less in increments (or close) of 3 amps that tells me how many magnets need to be replaced --------after inspecting wires and connections of course.
The trailer brake LIGHTS are not connected to the BRAKES so merely having lights does not mean the brakes have power.
I would start with the plug/socket where the trailer is connected to the truck and make sure the contacts are C-L-E-A-N with shiny metal contacting shiny metal. Then move to checking wires and connections under trailer.
Lastly, since this is an add-on controller, make sure the splice connectors that were used when it was installed are still intact attempting to pull wires out of each to see if they were crimped properly to begin with. Time can lead to corrosion in a loose connector so it pays to check.
01-30-2023, 05:35 PM
I had a similar situation a few years back where everything but the brakes worked. Using a volt meter we determine the brake connection in the 7 pin plug was dead so we started looking for a break in the line. Could not find it. I finally checked the voltage just ahead of the 7 Pin plug and had 12 volts going in but nothing coming out. Took the 7 pin plug off and the brake wire had corroded inside the sealed factory plug. A new 7 pin plug fixed the issue.
2018 Forester 3011 DS
01-30-2023, 06:19 PM
I was going to make a similar suggestion as TitanMike, but if you pull the breakaway pin, be sure the trailer harness is unplugged first. Brake controllers don't always take kindly to having power fed back into them. In lieu of a clamp on ammeter, you could also take a magnetic compass and bring it near the wheels while the breakaway is energized. If the compass deflects toward the wheel, they are probably working.
2023 Wolf Pup 14CC
2021 Ram 1500 4x4 3.6 V6
01-30-2023, 07:55 PM
once you know if the 12v side is actually working
check if your brakes may need adjusting...
Tarpon Springs FL
2022 Salem 24RLXL
01-30-2023, 08:46 PM
Do you think adjusting will clear the message the OP said he was getting on the controller "Trailer Not Connected".
Good chance the brake's are self adjusting anyway.
01-30-2023, 09:00 PM
Trailer brake emulator. Watch the LEDs. There are others but this is designed to work with Tekonsha controllers and is intended to make the brake controller think a trailer with brakes is attached. This can rule out the controller if it's the issue.
-- Chuck
2006 Roo 23SS behind a 2017 Ford Expedition
01-31-2023, 08:32 AM
I had this happen to me with a Tekonsha controller and the repair tec showed me it was the the actual position of the controller. It is meant to operate in either horizontal OR vertical position, not somewhere in between. I thought his solution was preposterous but the mounting screws had loosened (screwed into plastic) and when braking going down a steep hill I had nothing and the trailer pushed me all over three lanes of the interstate until I reached down and straightened the position to vertical and the brakes magically worked!
Roy
Roy
80 & Still Camping
2019 Rockwood 214HW
2011 Toyota Highlander
01-31-2023, 08:48 AM
Can you clarify the following "Brakes not activating. Power is going from the tow vehicle to the brakes."
What is the last point in the system are you seeing brake voltage? brake? Bargman connector etc?.
How are you determining that the brakes are not activating?
In many installations manufacturers use twist wire nuts to make the connections from the brake feed to the individual wheels. These are prone to pull apart or corrode and fail. This is always a good place to start. If this is the issue, I recommend cutting, restripping the wire and using solder and a piece of heat shrink tubing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-31-2023, 10:02 AM
Can't be. If there was power to the brakes they'd activate.
Did you test the brakes by pulling the break-away cable? This does not depend on the brake controller and applies full power from the trailer battery. Brakes should lock solid.
-- Chuck
01-31-2023, 10:06 AM
The Tekonsha Pilot is a 1950-tech time delay controller and can be mounted in any orientation as all it does is detect the current from the brake lights and apply 100% of set braking power to the brakes. Heck, it doesn't need to be mounted just connected to power.
-- Chuck
01-31-2023, 06:00 PM
Should have said "don't appear" to be activating. On second thought, they seem to be defaulting to a plain vanilla mode which doesn't allow controller adjustments of touch or strength and doesn't show the brakes as connected. Very strange.
2023 Geo Pro 19FD
01-31-2023, 06:05 PM
-- Chuck
Should have said "power is going out from the tow vehicle." I took the TV to U Haul (the guys who installed the controller). They stuck a trailer emulator in the 7-pin and determined that power is going out.
2023 Geo Pro 19FD
01-31-2023, 08:40 PM
Now start chasing the issue from the plug on the 7-wire cable all the way to the brakes.
Again, activate brakes while disconnected from TV by pulling breakaway switch pin then check for power in wires that go into each backing plate. If you have a simple test light that has an ice pick like probe just pierce each wire. One will be ground, other the positive. Positive should light test light, ground not or very dim ar most. If both are bright then ground is loose, probably in junction box.
Chasing lost power can be time consuming but it requires one to be methodical and patient.
Start where power is known to be present and work toward where it should be. If you loose it the fault is between the place you last had it anwhere you now don't.
Sent from my SM-N950U1 using Forest River Forums mobile app
01-31-2023, 09:04 PM
Will do that, much thnx. Though, I just tried an experiment -- using my Curt Echo Bluetooth controller (which I abandoned a while ago for the old "foolproof" Tekonsha; long story). Strangely, the Curt sets up and shows it's working just fine. Which leads me back to the Tekonsha which is not displaying codes and just 'seems' to default to a plain vanilla half-strength mode. I'm now thinking it's defective and not a wiring problem. Won't know for sure, though, til I try your suggestion and start tracing back to the brakes. Thanks again.
2023 Geo Pro 19FD
02-02-2023, 02:01 PM
Check junction box on frame of trailer that 7 way goes into problems there a lot of times!
02-06-2023, 07:53 PM
Great place to look. The wiring in the junction box is normally a mess and they use cheap crimp on connectors on the wires. I had a problem with running lights going dim once in a while. I could pull the wires out of the crimp. Replaced all of them with water proof wire nuts.
Another thing is a break in the wires under the trailer going to the axles.
Western PA
2015 Silverado Z71
2018 toy hauler
02-06-2023, 11:06 PM
Many thanks!
Bruce
I had this problem and traced it down to the crappy connectors near the axle. There are several poor wire connectors that could be your problem. I replaced them and problem solved.
2021 Rockwood A223HW
2019 Honda Passport Elite
