Old 09-17-2023, 04:13 PM   #1
bug screen for hotwater vent
I have been looking at this 4 Pack Flying Insect Screen for RV, but the large screen should really be 6.3" to properly cover the hot water vent.
Has anyone found something better?
What I like about this set is that it has a silicone antislip rim.
campingChris is offline   Reply With Quote
Old 09-17-2023, 05:17 PM   #2
Kanadian Kamper
kenandterry's Avatar
Not sure what your appliances look like, but here’s the grills for mine.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 09-17-2023, 10:23 PM   #3
A-frame owners likely know, but mine is like
The water heater is the black door near the front.
It has a 16x16 cm stainless steel grill and some black louvres 11x11 cm.
16cm is around 6.3" and thus bigger than the 6x6" screen available from Amazon.
Old 09-23-2023, 08:21 AM   #4
Gramps42's Avatar
The insect screens you need are 2 round screens that mount separately, approximately 2 1/2” in diameter.
Roy
80 & Still Camping
2019 Rockwood 214HW
2011 Toyota Highlander
Gramps42 is offline   Reply With Quote
Old 09-23-2023, 08:55 AM   #5
For the water heater?
That is what the OP asked about.
Days Camped '19=110 '20=116 '21=123 '22=134 '23=106
Old 09-23-2023, 10:32 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
I found some metal screening at Lowe's cut to fit and epoxy to inside of door. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 09-23-2023, 07:24 PM   #7
Gramps42's Avatar
Yes. Any rv dealer has them in their parts/accessories area
Roy
80 & Still Camping
2019 Rockwood 214HW
Old 09-23-2023, 08:33 PM   #8
Interesting... two 2" round screens might fit a furnace but would be worthless on a water heater with a 6.3" square vent as the OP indicates they have.
Old 09-23-2023, 08:38 PM   #9
Not sure how to take a link to the page but Amazon has them.
F. R. Wildcat 5th wheel 333 RLBS
2019 Ford F-250
Former US Navy 6/1968 - 3/1972
Retired forensic auditor 4/2022
Russellvh is offline   Reply With Quote
Old 09-23-2023, 09:19 PM   #10
easy fix
I cut two pieces of hardware-cloth the sizes needed, laid down a bead of caulk and then placed the wire screen into the wet caulk, ... when it sets up you have a lifetime fix, eight years and counting, ... quick, easy and permanent, ... ok, me using white caulk isn't exactly pretty, but that's on the inside and doesn't show, so that doesn't bother me, I suppose clear caulk would be a little less UN-Pretty, but in the end, this method is quick, easy and permanent, ...
fella10 is offline   Reply With Quote
Old 09-24-2023, 05:55 AM   #11
Mike223's Avatar
Screens
I use the hot water and heater vents. I put plastic ties to hold the hot water heater one on. Kinda hard for me to get the little springs to work. I put screen strips on my refrig.
Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
screen, vent, water
