Old 05-25-2019, 10:04 AM   #1
Happy AFrame Campers
yayus's Avatar
Bungee Replacement - Rivet Removal
Greetings Folks!
Have a bit of an esoteric tech question ... Looking to replace the bungees on the A122, and I'm interested to know how to access the bottom end of the lower roof's rivets (where the bungees attach to roof.) Do you have to remove the long strip on the inside of the roof section? I’m a little concerned about how far to drill into those rivets : )
Thanks everyone ... and have a fabulous camping season!
2013 Rockwood Premier A122
2006 Chevy Silverado 1500, Vortec V8
Northern California, Wine Country
yayus is offline   Reply With Quote
Old 05-25-2019, 08:50 PM   #2
Yayus, this is a fairly easy job to do. You don't have to remove anything on the inside. Have you viewed any of the youtube videos, especially Slim Potatohead's. Just follow his instructions and you shouldn't have a problem. I've replaced mine last year without a problem and I'm not that "mechanically inclined". You could say I know enough to be dangerous.
2016 T21TBHW
2017 Ram 2500 CTD CC SB 4x4
Ortep is offline   Reply With Quote
Old 05-26-2019, 12:01 AM   #3
yayus's Avatar
Thanks much, Ortep! Will check out Mr. Potatohead’s vid. Glad it’s probably not as complicated as I had imagined! [emoji106]
Old 05-26-2019, 02:45 PM   #4
Yayus, if you any questions after viewing the video, don't hesitate to ask more questions. After I had viewed the video, I still had some questions because of how my setup looked. I quickly figured it out though.
2016 T21TBHW
Old 05-26-2019, 04:19 PM   #5
yayus's Avatar
Thanks again. Mr. Potato’s Aliner has a slightly different means of attaching the lower roof’s bungees - if I don’t drill too far into the A122’s rivets rivets, should be OK (I think[emoji3]).
Old 05-27-2019, 09:54 AM   #6
You're right, as soon as the drill bit gets thru the rivet the resistance is gone (you're thru). Also, be generous with the chaulking, it's easy to clean up the excess AND you don't want water to be able to seep in thru those points.
2016 T21TBHW
Old 05-27-2019, 12:13 PM   #7
yayus's Avatar
[emoji106]
replacement
