I have small areas on the exterior that I found while traveling that need a bit of caulk. Is there a rope caulk out there that I can use for quick fixes? I really am not very adept at using a caulk gun and tend to make a huge mess when I try[emoji23]
I called and was told to use OSI QUAD Sealant which is available at Home depot and Menards, dont ever use any sealant with Silicone in it. If you are a messy caulker use painters tape just outside where you want the caulk to go, once caulk is in place and before it starts to skin over remove the tape
