Originally Posted by Jakeman33
Yeah, it's a fairly thin outer wall, so I'm not sure how well the drywall anchors will work...
I'm more inclined to try the gorilla glue... Why spray with water? And spray what exactly - the screw hole?
Water is what activates Gorilla glue. If you have some put a bead on something and spray it and observe.
Depending upon how large the hole in the wall is you could stick the screw through the mirror, put the glue on the screw, spray the screw, press the mirror and screw into the wall.
That being said: there's a crazy variety of drywall anchors/molly bolts out there and you could probably find one that would work.
I just have a hard time picturing how it's going to expand through the styrofoam and actually hold.
