Old 07-16-2017, 07:04 PM   #1
Filling toilet flush tank in A frame
How do you get the water tank filled on the FR A frames? I know where to fill but it doesn't accept more than what the fill tube allows. Is there a valve that needs opened of which I don't see?
Kenny Lee is offline   Reply With Quote
Old 07-16-2017, 07:19 PM   #2
ID:	145003Click image for larger version
ID:	145004Click image for larger version
16' T21DMHW - Gone solar - 3/4ton truck to pull it with
glarior is offline   Reply With Quote
Old 07-16-2017, 07:21 PM   #3
Fill the water from that filler cap in first pic. Its like a ptrap and always has water. The clear tube to the right is your fill line. I fill mine to about where my finger is. Currently mine should be topped off before next trip. Hope this helps
Old 07-16-2017, 09:23 PM   #4
MontyPP's Avatar
I thought the water came in from the city/freshwater tank. The green cap is removed to dump the waste. Button inside in the cassette flushes fresh water into the tank.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 07-16-2017, 09:44 PM   #5
Not on the aframe toilet cassette unless older models are different? There is another green cap on the tank when you remove it to dump it out. I was told that it only holds enough water to fill the tank that way it wont overflow.
Old 07-17-2017, 05:51 AM   #6
194'er
Jaydubya81's Avatar
Well glarior I thought the same thing, but the clean water will fill the little waste tank a couple of times over, you have to account for all the other stuff beside fresh water that's going into the waste tank, I fill it up after every trip, but it's never more than half gone even , but my waste tank was full way before the water runs out.
Jaydubya81 is offline   Reply With Quote
Old 07-17-2017, 08:42 AM   #7
Yikes! Good to know
Old 07-17-2017, 12:02 PM   #8
I thought the same thing. I don't remember seeing a fill tank spout. I have to look at mine again.
2017 Coachman Viking 21RD
2018 Chevrolet Colorado with tow package
lcangler is offline   Reply With Quote
Old 07-17-2017, 12:52 PM   #9
You need to pull the cassette out from the toilet in order to fill it. 1/2 bottle of toilet chemicals and 1 quart of water
Steve H
Rockwood A213HW
sholdeman is offline   Reply With Quote
Old 07-17-2017, 01:03 PM   #10
MontyPP's Avatar
Evidently I have an upgraded toilet. It has connection to the water supplies.
Flagstaff T21TBHW
Old 07-17-2017, 01:04 PM   #11
MontyPP's Avatar
ID:	145055Click image for larger version
ID:	145056Click image for larger version
Flagstaff T21TBHW
Old 07-17-2017, 01:38 PM   #12
Interesting! Which model/year is your camper
Old 07-17-2017, 01:54 PM   #13
lastayt's Avatar
We have a 2017 A213HW. Our cassette toilet is connected to our water supply also. It does not have a separate water tank of its own.
lastayt is offline   Reply With Quote
Old 07-17-2017, 02:33 PM   #14
MontyPP's Avatar
Mine is the T21TBHW
Flagstaff T21TBHW
Old 07-17-2017, 02:34 PM   #15
MontyPP's Avatar
Mine is the T21TBHW
2017
Flagstaff T21TBHW
Old 07-18-2017, 07:53 AM   #16
194'er
Jaydubya81's Avatar
That's cool that the newest ones have a water line ran to them.
By the way you do not have to remove the cassette to fill with water, you simple pour water in the spout with the green cap the OP is pointing at in the first picture
Old 07-18-2017, 09:02 AM   #17
That is a new feature. Mine is a 16 model and does not have it. Now I know they changed it in '17
Old 07-18-2017, 02:41 PM   #18
MontyPP's Avatar
I think they changed a few things in the 2017s. The skylights seem to be better/differently sealed from the factory as well.
Flagstaff T21TBHW
Old 07-18-2017, 02:53 PM   #19
That's a Thetford toilet. I suggest you do what we do when all else fails:
READ THE INSTRUCTIONS!
2011 Traverse LT, 3.6L, FWD
Old 07-19-2017, 07:19 PM   #20
Thanks. However, the receiving tube will not accept any additional water other than what it takes to fill it up. I followed directions to remove the waste tank prior to filling but it does not help. Something is keeping it from filling or ??
flush, frame, tank
