Originally Posted by Zoinks
Very nice. A quick rookie question. I'm assuming that in storage 110V and 15 amp is plenty since everything should be off? I noticed you said you are plugging into 30 am. It's only keeping the batteries charged. Is that correct?
I have run the A/C OR the microwave plus an inspection lamp, a small vacuum cleaner, and converter from a 15A garage circuit. This is when I pull the unit out of the garage and into the driveway to raise the roof and walls and work on it. I have an extension 30A cord plus the camper 30A cord that I use with a 15/20A adapter into my 15A garage circuit.
Inside the garage, I use the camper 30A cord with adapter to charge batteries and run the fridge when desired.
I do have to remove my spare tire to fit into the garage. I hate that, but I've gotten the spare install or remove down to about 5 min now. I need the spare mounted to help reduce tongue weight when towing. (I tried without the spare mounted, amazing that it made a noticeable difference in the way the camper towed.)
Fred W
2019 Flagstaff T21TBHW A-frame
