09-30-2017, 02:56 AM
FM Radio reception
I have a new Rockwood A122S A-Frame with the Kenwood radio in it. Have any of you had a problem with reception on it?
Sometimes, at home, I can get a handful of the local stations on it. Other times it seems deaf. I was out in a very remote area recently and thought I'd see if I could find something to listen to, but it was dead.
A USB stick with music files on it works fine.
I pulled the radio out one time to make sure the antenna was plugged in tight. Reception improved sometimes as I moved the wiring around, but I couldn't get anything consistent.
I am skeptical about the little antenna on the wall next to the door being a very good antenna. In an automobile, the whip antenna works against the metal of the car body. But, in this case, it's all fiberglass and plastic. No ground plane.
The radio isn't very important to me, but I do know a thing or two about radios and electronics, and I'll get it working eventually. I just thought I'd ask if anyone had noticed this problem before and had a solution.
09-30-2017, 09:57 AM
Mine does the samw thing. The antenna is in a bad place. Sometimes me being near it can help the signal or make it worse.
16' T21DMHW - Gone solar - 3/4ton truck to pull it with
09-30-2017, 10:36 AM
What type of antenna are they putting on those ? My 2018 Cherokee has the flying Saucer Omnidirectional that handles the TV and Radio....I'm not impressed at all with it. Our old crank up TV antenna and separate automotive style radio antenna out performed this new one by a long shot.
09-30-2017, 11:07 AM
I dont think its the type of antenna causing the issue. It is where they mount the antenna.
09-30-2017, 11:08 AM
TheWolfPaq82, it's a floppy. Grounding is provided by the radio ground. It could possibly be replaced by a spring loaded or extendable type anttenna.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
10-01-2017, 08:00 AM
Antenna?
I just figured out that is an antenna! All these years we thought it was for hanging a plastic grocery bag on for trash.
Mark
Michigan
2014 a122s
2014 Tacoma Double Cab
My YouTube Channel
Days Camped 2016/2017/2018/2019: 98/106/109/73
10-01-2017, 08:23 AM
My brother-in-law has a older Jayco, 2010 I think. Has the spring loaded "Floppy" antenna...like our 2007 Jayco had and I'm still trying to figure how the HECK ! he bent the top half to a 45 degree angle. But then again...my B.I.L. has done some weird sh*t to his camper that I've fixed from time to time.
10-01-2017, 04:16 PM
That is exactly what I have experienced. It's very sensitive to anything around it. Touch it, move it, open the door, everything changes. A sure sign of a poor antenna with no ground plane.
10-01-2017, 04:17 PM
That's about all it's good for!
10-01-2017, 04:20 PM
Could run a copper wire to the frame or to the ground.
Flagstaff T21TBHW
10-01-2017, 04:29 PM
In my rockwood, I had the same problem
Figured out they install antennas that needs a ground.
Screwed to the fiberglass side, there is NO ground for it.
I bought a "no ground" antenna and plugged it in and I get all the same stations I get in my truck.
Cheap a** factory!
Mark B.
2021 GMC 1500
Anderson WDH
10-01-2017, 04:51 PM
Cheap a** factory!
I'd be interested in any information you could provide on your "no ground" antenna.
It is definitely a ground issue - technically counterpoise - and there is no ground in the wall of the trailer.
I took mine apart and looked at the insides. The fitting at the end of the cable had a short piece of the shield sticking out. On a metal surface, such as when mounted in an automobile, the shield side of the cable would connect to the body through the mounting. Does no good to connect it to fiberglass and styrofoam, though.
I took about 3 ft. of hookup wire and connected it to the shield and it made a slight improvement. It's still sensitive to movement around it.
10-01-2017, 04:54 PM
Mark B.
2021 GMC 1500
Anderson WDH
10-01-2017, 04:58 PM
You are right, but it's a lot of work to get inside to do that.
There are different kinds of grounds. What this needs if an RF ground, and while connecting to the frame may or may not provide that, what it really needs is a counterpoise or a wire to provide a balance to the whip antenna.
I added about 30" of wire to it at the back of the antenna and it made some improvement. I just stuffed it in the hole when I put the antenna back on.
I tried touching it to the door frame to see if it made any difference and the results were pretty random.
10-01-2017, 05:29 PM
Yeah. Thanks. I know the theory, I'm an electrician and electronics hobbyist and have been a Ham Radio operator for 40+ years.
Just hoping someone else found a solution before I reinvent the wheel.
10-02-2017, 12:14 AM
Actually I tried that back in July thinking that the problem is the ground plane. As other's have stated, just standing by the antenna makes the reception change. This summer I had the microwave out to do a modification to the cabinet and noticed that the antenna ground wire was just flopping loose, not hooked up to anything. So I temporarily ran a wire clamp from the antenna ground wire to an unpainted bolt on the frame. It made no difference in reception.
Next year I am going to remove the cheap AM/FM/CD Jensen radio, and install a low cost AM/FM radio with Bluetooth. That way I can stream Pandora, etc. from my phone.
2016 Coachmen Viking Legend 12RB A-Frame
2015 Jeep Grand Cherokee Summit w/Tow package
