Old 09-21-2020, 06:24 PM   #1
Foul odor in hot water tank
We de-winterized back in May but didn't use the camper until this weekend. We filled and drained the water tank back in May, but I must've skipped the hot water tank. We got the camp all set up, water all filled up and hot where appropriate. I went to wash my hands and the nastiest smell came from the hot water and it was pink. I wonder if some antifreeze got in there and grew something scary while it sat empty. Any ideas on how to sanitize it so we can use it without worrying about catching something else (other than Covid-19)?
Jackie & Nate
West Michigan
2015 Viking V12RBST
2019 Chevy Colorado
rmebrat is offline   Reply With Quote
Old 09-22-2020, 07:16 AM   #2
SeaDog's Avatar
This happen all the time when you don't drain your WH for an extended period when not in use. All you have to do is dump the tank and refill and all will be good remember you still have to flush the water out of the lines. RV antifreeze did not do this. This has happened to me several times when I didn't drain the tank.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-22-2020, 07:26 AM   #3
Flybob's Avatar
The natural bacteria in the water had a chance to grow for several months. Flush it and you will be OK.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-22-2020, 08:08 AM   #4
Thanks for the advice. I was hoping it would that simple!
Jackie & Nate
West Michigan
2015 Viking V12RBST
2019 Chevy Colorado
Old 09-22-2020, 01:06 PM   #5
You should check the anode also. May need replacement
Harkerr is offline   Reply With Quote
Old 09-22-2020, 01:56 PM   #6
Sulphur Dioxide smell
The smell you have is Sulpher Dioxide or rotten egg gas. It is formed by anaerobic bacteria feeding on the Magnesium anode rod. The cure is Hydrogen Peroxide in the heater.
You will want to drain the tank and dump some Hydrogen Peroxide into the tank, best done through the temperature/over pressure relief valve on the heater. Unfortunately it points downward. So go to your hardware store and get a 3/4" male pip to barb fitting (plastic) and some tubing to fit on the barb of the fitting. This will allow you to pour H2O2 and water into the heater tank.
If you don't want to do this the at a minimum take out the anode rod, clean it to get rid of some of the white stuff and wash it in Hydrogen Peroxide. Flush the heater a couple of times and it should get much better. In to future, drain the tank if you are not going to use it for several weeks and leave the rod out of the heater. Even better is to go camping more.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 09-23-2020, 05:36 AM   #7
This is True's Avatar
I was wondering why leave the anode rod out of the heater when empty storing for winter?
Won't critters get in ?
Were retired What day is it?
2017 XLR Hyper Lite 29HFS Toy Hauler
2013 Silverado 2500HD, Ext. Cab, 6.0L, 4x4
Harleys in the garage & our Lab in the backseat... Abby, aka Abbygator Slobber Nasty
This is True is offline   Reply With Quote
Old 09-23-2020, 06:57 AM   #8
Only if you have a Critter problem. I never had a Critter problem storing in driveway, so I left my Anode out during the winter.
TheWolfPaq82 is offline   Reply With Quote
Old 09-23-2020, 07:10 AM   #9
wmtire's Avatar
See video #5 here, where we keep instructional videos from Suburban about their water heaters. It will explain the causes and removal of the rotten egg smell.
https://www.forestriverforums.com/fo...es-135977.html
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
Old 09-23-2020, 09:11 AM   #10
Thank you! The smell coming from the tank is worse than rotten eggs, if you can imagine such a smell, so I'm going to do the bleach flush. This video is really helpful! Thanks again.
Jackie & Nate
West Michigan
2015 Viking V12RBST
2019 Chevy Colorado
Old 09-23-2020, 09:52 AM   #11
Villagerjjm's Avatar
You can get a PVC plug, drill it out and insert a faucet washer with a screen. That will allow for air flow and keep out the “critters”.
Villagerjjm is offline   Reply With Quote
hot water, tank, water, water tank
