I am now a member of the Linear Actuator Failure club.
I read a lot of the posts about the actuator so when I was using mine it seems not to be able to open my camper all the way without help. So I contacted my seller and was sent a new one under warranty. I put it in my storage box.
Sure enough two camping trips later the actuator failed. Glad I had a spare.
After returning home I decided to take the thing apart. Found water inside and the gear grease was also retaining water.
I cleaned up the water and grease. I installed new grease and sprayed the inside with WD40. Put it back together and tried it out.
I operated the actuator 10 times and it worked great. Even seemed to work better than ever.
I have had three more camping trips since then and no problem.
Camper is now winterized and waiting for next spring.
I forgot to tell you what camper I have.
It is an Rockwood A213HW. 2019 model.
Happy camping to all.
