Originally Posted by Murph60
My first intent on this post was confirm what valve controls the FWT drain when I am done camping. That has been answered.
My follow up question was do I run the risk of damaging anything if I run the tank dry during normal use while camping and whether I need to monitor the water level before the faucets run dry. If I let the faucets run dry and the hot water heater is still on, don't I run the risk of frying the heater?
I'm sorry, I misunderstood the second part of your question. RV water pumps are diaphragm type pumps. They will not be damaged by running them dry. The pump will actually be quieter when the FW runs out, the pump will run faster, but quieter. That being said, there is no need to run the water pump with the FW tank dry, so as soon as either the pump runs fast and won't shut off, or you get air out of your faucets, you should turn the pump off until you refill the FW tank. Then it will take a little bit of pumping air with the fresh water pump (with a faucet open) in order for it to prime itself.
The water heater should not be damaged by pumping the fresh water tank dry either. There is a check valve in the bottom (cold water inlet) of the water heater that will keep water from flowing from the tank back into the cold water side. The hot water outlet is at the top of the tank. So, if you should pump your freshwater tank dry, and open a hot water faucet, air will get pumped into the bottom of the tank and it will rise through the water and be expelled through the hot water outlet. There should be enough water that stays in the tank to keep it from being damage if the heating source is left on.
Again, though, this should not be a normal practice. As soon as you know you are running out of water in the fresh water tank you should turn off the water pump and turn off all sources of heat to the water heater. But, if you don't and things run for a while with the fresh water tank dry, nothing should be damaged.
