05-29-2023, 02:32 PM
Gas Alarm When Using Water Heater
Having a problem with my propane water heater triggering CO/Propane alarm on my 2-year-old Flagstaff T12RB A-Frame popup. It seems to happen primarily in windy conditions when a gust will come in through the exterior exhaust vent of the water heater and extinguish the flame. This, in turn, automatically restarts the ignition sequence. Suburban, in their documentation for this model (SW6D), does state that the system undergoes a "purge" at the start of each ignition cycle, and this probably explains the detectable gassy odor (and therefore the alarm) after a few off-on cycles. (I was able to replicate the problem by directing a fan at the outside vent and shutting all doors and windows inside the camper.) So, I'm considering building a sheet metal wind deflector to mount around the exterior vent. But I'm not quite sure how the "purged" gas is getting into the camper in the first place. Is this to be expected after several ignition cycles? Should the flame be so easily extinguished in windy conditions? Has anybody else had experience with this problem? Ideas / suggestions from the community would be MUCH appreciated. Thanks!
05-30-2023, 10:18 AM
Haven’t experienced that on our T12RB and have been in some really windy conditions.
As far as a wind shield, we did have issues with the standing pilot blowing out on a previous trailer. I purchased an RV wind shield and added magnets so I could stick it on the water heater access door when conditions required it. Worked quite well.
2021 Flagstaff T12RB
2015 Jeep Cherokee Latitude
05-30-2023, 10:25 AM
Kanadian Kamper
Not sure what an RV wind shield looks like. Got any photos?
Ken and Terry
05-30-2023, 02:02 PM
PapaGlenn - can you send a link to the wind shield product you have, pls?
05-30-2023, 03:02 PM
I can’t find it online but I’ll look and see if I still have it or can find a picture.
EDIT: must have left it in my last RV when I sold it. It was basically a rectangular piece of sheet metal. From the side, it looked like this (ignore the it that sticks up past the top):
__|—————-|__
Overall finished size was slightly smaller than the water heater door. It was installed to the door with screws through the bottom of the “L” and through 1” spacers so the wide flat part sat about 2” away from the door. I put magnets on the end of the spacers so I could use it only when needed. I’ll see if I can find a pic of it installed.
06-02-2023, 04:05 PM
Helpful, thanks! In somewhat similar fashion I ended up bending a piece of sheet metal into a flat U shape and attaching it to the exterior flange of the water heater compartment with sheet metal screws. It's like a 14"wide x 8"tall x 2"deep chimney that's open at top and bottom. I can still access the panel to remove the hatch, extract the anode, press the reset buttons or trigger the pressure relief valve - all without removing my new wind deflector. Now, if it just blocks the wind and keeps the burners lit I'll be a happy camper.
06-02-2023, 04:17 PM
Here's a photo:
https://www.forestriverforums.com/PhotoPost/showphoto.php?photo=5759[/IMG]
06-02-2023, 05:34 PM
Sounds like a good solution. I saw pictures of something similar when I was looking for pictures of the one we had. Also, you also need a “[IMG]” in front of the URL for the picture you linked for it to work.
06-02-2023, 08:57 PM
Ahh, yup, missed that one:
06-03-2023, 12:37 PM
The shield/wind blocker looks like an easy yet functional addition.
I'm keeping this in mind for the future. There's been no false CO or propane alarms here yet . . . Doesn't mean that it won't happen in the future tho. . .
Thanks for posting!!
2012 Rockwood A122, 2017 2018 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT & the 2017 Sorento have gone to TV heaven))
Cheers and greetings from a Toronto Canuck
06-03-2023, 04:47 PM
We had LP alarms in our Mini-Lite under windy conditions in CO last year. I tried to build a temporary wind screen with aluminum foil without much success.
Related to that, I replaced the CO/LP alarm with an LP alarm and added a CO alarm on the ceiling. It wasn't defective but it was maddening trying to figure out what caused the alarm. Labels on the trouble lights are tiny and located at floor level. DW and I have old eyes and old knees, so that doesn't work. Now, one of them alarms, we know what they problem is.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
06-03-2023, 05:38 PM
I'd been considering separate alarms for carbon monoxide and propane, and I may try this next. I agree that having both features in the same device (especially when it's screaming at you from under the table) is ugly. But we're about to take the rig on the road for a week, so we'll see first if my new wind deflector makes a difference.
Thanks!
06-10-2023, 07:32 AM
Here's a photo:
Not only are you missing the [ IMG ] tag, but it looks like it's the wrong picture also...
2022 Rockwood A122S "Rocky"
Mitsubishi Outlander PHEV "Phevy"
GTA, Ontario
(before) 2003 Coleman Santa Fe
06-10-2023, 11:02 AM
The pic that is linked shows a wind guard very similar to the one I purchased years ago. Should do the job.
06-10-2023, 12:16 PM
Yes… here’s the pic:
