Old 06-20-2022, 07:48 PM   #41
Doppleganger's Avatar
Originally Posted by clhjsh View Post
I have been using these red rubber roll on caps. By far the best I have found to keep caulking tubes usable.
https://www.amazon.com/dp/B08N4B9MZG...37711DMEBT689Z
This is the correct answer.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
Doppleganger is offline   Reply With Quote
Old 06-20-2022, 08:09 PM   #42
bob213's Avatar
Originally Posted by nvs4602 View Post
I have to have a picture of this idea with it in the refrigerator. My wife would never let me put it in her refrigerator, heck she won't let me keep my fishing worms in there neither.
That's kind of funny. In my house I'm the cook. I could keep my tool box in the bottom drawer of the refrigerator and I doubt my wife would ever see it.
She's lucky to find the jug of milk.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 06-20-2022, 08:44 PM   #43
Who Dares, Wins
doc73's Avatar
Hopefully she's not on the forums....
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 06-20-2022, 08:48 PM   #44
Bees wax/toilet ring
2023 Dynamax Force HD 34KD (Arriving November 22)
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
NewToTheForce is offline   Reply With Quote
Old 06-20-2022, 09:00 PM   #45
Originally Posted by Brandoni View Post
Question to all of you that have caulked your mobile homes.
How do you seal your opened caulking tube?
I've tried screws and plastic wrap . . . the caulk cures down the tip (getting wider as it goes) necessitating digging out the cured material. The tip end is getting larger and more ragged each time, the extruded stream is now textured and looks like a fancy cake decoration . . .
If I keep this up the RV will look good on the baker's shelf waiting for Hansel and Gretel to drop by . . . (Aren't those A Frames just like cute Swiss Chalets . . . missing the flowers in the window box . . .
Thanks for replying
Cheers!
They sell caps for the end of the caulking tube at pretty much every hardware store.
Lowes item #: 419994, $1.98 + tax
Walmart: https://www.walmart.com/ip/213072234
Happybear 20/50pcs Latex Caulk Saving Cap Re-Sealable Caulking Tube Nozzle Tips Covers, $9.98 + tax
Lighting546 is offline   Reply With Quote
Old 06-20-2022, 09:08 PM   #46
We use a screw to plug ours.
Toothie12 is offline   Reply With Quote
Old 06-20-2022, 09:54 PM   #47
Golf tees
I agree with others that the caulk will only last so long, but gold tees are tapered enough to sclog the hole real nice.
CTRoo is offline   Reply With Quote
Old 06-21-2022, 06:30 AM   #48
Aluminum foil
Plastic wrap has a “perm rate” that lets vapor pass. Aluminum foil does not. Make a blob of sealant and wrap with foil. Wrench it off and toss it each time. A gutter spike makes a good long reach down to the good stuff if you have one that has dried up.
Papadave is offline   Reply With Quote
Old 06-21-2022, 08:38 PM   #49
Commercial Member
Thanks for replying
Cheers!
I have used these with great success on a number of different sealing tasks.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Next Aug 23- 27 2022 Lincoln, NE
Tireman9 is offline   Reply With Quote
Old 06-21-2022, 09:55 PM   #50
I just let it dry and seal itself. Then when I need it I take a razor knife and slit the nozzle on the opposite side of the caulk flow, and dig out the plug. Then I wrap the nozzle with a piece of duct tape.
The only reason to slit the nozzle on the opposite side of the caulk flow is to avoid leaving a trail from the slit.
2020 Sunseeker 2860DS
n1acguy is offline   Reply With Quote
Old 06-22-2022, 12:22 PM   #51
Thanks for replying
Cheers!
depending on how much you cut off the tip i use a large wire nut and electric tape . works for couple months but many times it will start curing from the tip down .
MR.M is offline   Reply With Quote
Old 06-22-2022, 12:23 PM   #52
Those are nice never seen them before . now got something else to buy.
Old 06-22-2022, 09:05 PM   #53
Originally Posted by Mjeronimo View Post
I’ve had good luck with foil tape-3” piece make sure past tip 1/2 to 3/4” wrap around a few times twist tight fold over.
Same for me. I will put a large wire nut on and then the foil tape. Works well for me.
JVthePT is offline   Reply With Quote
Old 06-22-2022, 09:47 PM   #54
I use these, still only limited success.
Name:	Screenshot 2022-06-22 10.44.50 PM.png
Northern Indiana
2018 Salem Cruise Lite M-241QBXL
2018 GMC Canyon Denali
Rick the Rocket is offline   Reply With Quote
Old 06-23-2022, 12:48 AM   #55
rvflyer57's Avatar
I have actually had good luck dispensing a healthy amount from the tip, rotate the tube until a dime size ball is formed at he tip and let it dry. Next time I need it, I pull on the glob and it pulls out a small amount of dry caulk from the tip, and it’s fresh behind it. Works 90% of the time.
2021 MiniLite 2513s SOLD
2-190w solar
2020 Ram 1500 Laramie 5.7 Hemi e-Torque 3.92
1940 Chevy Special Deluxe
1946 Aeronca 7AC Champion
rvflyer57 is offline   Reply With Quote
caulk
