06-14-2022, 09:55 PM
How do you plug your caulking tube?
Question to all of you that have caulked your mobile homes.
How do you seal your opened caulking tube?
I've tried screws and plastic wrap . . . the caulk cures down the tip (getting wider as it goes) necessitating digging out the cured material. The tip end is getting larger and more ragged each time, the extruded stream is now textured and looks like a fancy cake decoration . . .
If I keep this up the RV will look good on the baker's shelf waiting for Hansel and Gretel to drop by . . . (Aren't those A Frames just like cute Swiss Chalets . . . missing the flowers in the window box . . .
Thanks for replying
Cheers!
2012 Rockwood A122, 2017 2018 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT (gone to TV heaven))
Cheers and greetings from a Toronto Canuck
06-14-2022, 10:08 PM
I do the same - screw and plastic wrap.
For certain marine sealants (3M 4000, 4200), seal the tip in similar fashion and place in a freezer. This greatly prolongs the service life, just thaw well before the next use.
2022 MiniLite 2109s
2018 F-150 XLT 4x4, 3.5L, Max tow pkg
2019 Ranger Lariat 4x4 (in reserve)
(We're just getting started!)
06-14-2022, 10:11 PM
There are lots of youtube videos with suggestions. The one I like most is this one. https://www.google.com/search?q=how+...eqtsP3-C2oAs17
However, nothing keeps a caulking tube more than a few months.
2015 Dynamax REV 24TB class C
06-14-2022, 10:24 PM
long nail in the tube end. plastic wrap or plastic glove finger over the nail and around the end, then wrap with packing tape or duct tape.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
06-14-2022, 11:23 PM
I do the nail/plastic/and tape then I seal in a vacuum sealer and keep in refrigerator.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
06-15-2022, 12:26 AM
Foil tape
I’ve had good luck with foil tape-3” piece make sure past tip 1/2 to 3/4” wrap around a few times twist tight fold over.
06-15-2022, 06:16 AM
Part-Time Campground Host
Black electrical tape.
Craig & Cath
Days camped since 2015(retirement): 1659
06-15-2022, 06:21 AM
06-15-2022, 06:45 AM
This. I insert a screw then wrap a lot of black electrical tape around it. Seems to keep for several months.
2008 Berkshire 360QS w/MBE926
06-15-2022, 08:08 AM
Who Dares, Wins
I guess I've always just expected a one time use of the tubes once I've sealed it will be a while before I use it again and by then they seem to have expired due to age.
2015 Chevy HD D-Max
2022 Impression 315MB
06-15-2022, 09:01 AM
Canadian Member
I’ve tried a few methods to seal caulk tubes but, like doc73, I don’t use them often enough to be worth the effort. So I consider it a one time use. I have the same issue with a can of expanding foam. The applicator tube is not reusable.
06-15-2022, 09:18 AM
I have found using red wire nuts the winged ones works good for me mainly though I usually buy just enough for the job save what's left and throw it away after about 3 months. use a permanent marker and date the tube.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
06-15-2022, 10:53 AM
I have been using these red rubber roll on caps. By far the best I have found to keep caulking tubes usable.
https://www.amazon.com/dp/B08N4B9MZG...37711DMEBT689Z
2013 Itasca Ellipse 42QD
-2012 Lexington 265 GTS- Sold
Tow Vehicle 2017 GMC Acadia
06-15-2022, 11:37 AM
Originally Posted by clhjsh
These are what I have used successfully for years. Caulk condoms my wife calls them. They keep most things reusable but some products such as adhesives only have about a year or so shelf life anyway so I usually toss them after one use.
06-15-2022, 11:40 AM
Pseudonym
dip it in CANDLE WAX!!!
2021 Shasta 18FQ
2023 Ram 1500 4X4 Lone Star Crew Cab 5.7L HEMI eTorque
Attachment 251949
06-15-2022, 12:25 PM
I don't even buy and open caulk until I have a list of everywhere it's needed - then if there's any significant amount left in the tube, I'll keep it around but toss after a month or so. Usually the push cap in the tube will leak or blowout when I go to use a previously open tube of caulk, especially if it's sat around a few weeks, and it's not worth the mess of trying to use it.
Sent from my SM-A505U1 using Forest River Forums mobile app
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
06-15-2022, 01:03 PM
https://www.amazon.com/gp/aw/d/B07D5QHJ19?ref=ppx_pt2_mob_b_prod_image
06-15-2022, 01:51 PM
Duct tape. Wrap tightly with about 1/2 the width of the tape in contact with the tube, pinch the rest of the tape tightly, then bend the tape to enhance the seal. This holds up for months.
NOTE: The act of the caulking gun pushing the plunger in the back of the caulking cartridge also breaks a factory seal and accelerates deterioration of the contents. You might get lucky, and the plunger/ram in the tube may continue to seal very well, but you might not.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
06-15-2022, 02:00 PM
Sealing Caulking tubes
I use a big wire nut, the red or yellow ones. Even then, the caulking will go bad in 3 to 6 months of a partially used tube. I probably throw away more than I use.
In this regard, I often buy toothpaste size tubes as opposed to the caulking gun size. Less waste. Just depends on the size of the job.
06-15-2022, 02:38 PM
Get a wax toilet gasket and push the open caulk end down into wax gasket. When you need to use again just pump the wax out. Save caulk for years.
https://www.lowes.com/pd/Oatey-Johni-Ring-Wax-3-in-Toilet-Gasket-for-Universal/5005332087
