Originally Posted by Rook21
Thanks to everyone for the responses. We are still considering the A122 or T12RB and still can't find one within a 3 hour drive.
Does anyone have actual loaded weights and loaded tongue weights (not the published weight in the brochure)? I read on another post someone had a loaded tongue weight of 400 pounds which surprised me.
At this point, we're looking at A122/T12RB, A-Liner Scout, or needing to upgrade our tow vehicle. Thanks again for all of your help!
We had a 2014 A122 before we moved to the high wall in 2018. Actual loaded weight was 2730lbs with full water the one time we scaled it. 390lbs on the tongue.
We towed the A122 (and now our 2018 T21TBHW) with a 2008 Hyundai Entourage (re-badged Kia Sedona) minivan. We added a second battery from the beginning to support dry camping for 4 nights without a generator or solar. With the 2nd battery, our tongue weight was getting up there.
The A122 has the advantage/disadvantage of no front storage box. The front storage box is an easy way to boost the tongue weight by 100lbs (even though book says not to put more than 150lbs in front storage box). You have to work on keeping the weight of stuff in the back of an FR A-frame to keep the tongue weight where it should be. Traveling with full water helps as the tank is behind the axle.
We went with an E2 Equalizer 600/6000 after our first attempt to tow the A-frame with the minivan. The soft rear suspension sagged more than I liked, and the trailer started porpoising - bobbing the nose of the A-frame and the rear of the minivan at low speeds. The E2 WDH fixed everything - I would not tow this size trailer without it again. It does add 4 minutes with a manual tongue jack to get the WDH bars on/off.
I added a washer to the E2 when we bought the bigger A-frame. But the difference in towing different trailers with a minivan is trailer frontal area, not weight. Having towed 2 different A-frames, and 2 different enclosed U-Haul trailers (no WDH) with the same minivan, I can say that trailer frontal area is the controlling factor in gas mileage, gear used at a given speed, and overall feel. The A122 (with the WDH) was the easiest to tow, got pretty good gas mileage (17-19 towing compared to 21-23 not towing), and hardly ever left top gear on the highway. With the WDH, DW was comfortable driving while towing the A122.
The T21TBHW A-frame feels significantly harder to tow, even though it only weigh 200-300lbs more in camping trim. The extra air resistance of the high wall and the dormer are noticeable, especially since they stick up above the roof of the minivan. I did add a washer to the same WDH, and am happy with the weight distribution.
With the high wall towed by the same minivan, I get 14-15 mpg at the same speeds, 13 mpg if I go faster (I now have 75mph tires instead of 65, so tow at 72-74 when conditions and speed limits permit).
Forest River has heavier A-frames than A-liner for around 1/2 the cost. FR also locates the axle further back to improve handling and almost eliminate sway, but the result is a heavier tongue weight.
Use a WDH with your A-frame and towing with a minivan. It will put a smile on your face, and relax your drive.
just our experiences
Fred W
now 2019 Flagstaff T21TBHW A-frame
prev 2014 Rockwood A122 A-frame
