Old 09-26-2015, 02:44 PM   #81
Just a member
kandl's Avatar
Originally Posted by gljurczyk View Post
Don't give the Canadians any idea's they came up with the square screw heads....
This thread is starting to come apart at the seams...
And don't get me started about dealing with two systems of measurement.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 09-26-2015, 02:50 PM   #82
Ford Idaho's Avatar
Originally Posted by wana65stang View Post
Yes they have a colour ( not color) code and they are the BEST design for not slipping when you are driving them in.
“You like to-may-toes and I like to-mah-toes"
Old 09-26-2015, 09:00 PM   #83
Never would have thought there could be so much input on changing out an anode rod!!
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-27-2015, 07:43 AM   #84
Wolverine 1945's Avatar
Originally Posted by Iwannacamp View Post
Friend of mine sent his young daughter to get a screw driver....
She came back and asked.... Is it a + or a -
(Plus or a minus)
Smart Girl !!!
I like the way the Square / Phillips works
They should outlaw the Minus one !!!
LOL !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-27-2015, 05:56 PM   #85
The suspense is over
My anode rod after 3 years and all the calcium deposits on the ground after a very good flush.
Name:	IMAG0035 (296x480).jpg
ID:	90070   Click image for larger version
Name:	IMAG0036 (271x480).jpg
Old 09-27-2015, 06:44 PM   #86
Iwannacamp's Avatar
Same as mine after less than three
2017 Puma 297RLSS
Old 09-27-2015, 06:48 PM   #87
Ignorance is bliss. I won,t be waiting more than a year going forward. Already have a new rod ready for next year, and will drain the tank between trips !
Old 09-28-2015, 06:24 AM   #88
WOW guys,,, where are you getting your water ???
We had a Flagstaff TT for about 8 years,,, Anode never go to that point !!!
Maybe the filtered soft water we use helps ???
Old 09-28-2015, 06:38 AM   #89
Dave Lyon's Avatar
X2
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 09-28-2015, 07:17 AM   #90
PhoneDude 8289's Avatar
Originally Posted by Kenny kustom View Post
It's pipe thread, is it not?
Teflon and snug.
2008 F350 CCSB V10
2016 Sabre 36QBOK
X2. The first time I pulled it last fall I had to use a 1-1/6 socket, extension and breaker bar. Now it's teflon and snug it up, comes off real easy now.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-28-2015, 07:22 AM   #91
Right On !!!
As I said it is not a lug nut,,, or a mower blade !!!
If it does not leak,,, it is plenty tight enough !!!
Old 09-28-2015, 09:35 AM   #92
deartruc's Avatar
Only used our new 2015 once last fall for a 4 day trip. Dealer winterized it for us when we got back (it was in for warrantee work). The side of the camper was soaked in calcium.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 06-13-2016, 11:44 PM   #93
JArry's Avatar
Hate to revive an old thread, but...
This seems like the logical place to post. I am wondering if it is normal or necessary for the anode rod nut to be completely tightened flush with the outer edge of the drain hole. Mine shows about 1/4-inch of exposed threads and is very tight to the point that I think additional tightening would risk stripping the threads. Last time I tightened it to a seemingly reasonable amount, water leaked around the rod. It is thread-taped. I mentioned the leak to the dealer; I think they tinkered with it, and they claim the leak was fixed. However, it doesn't look like they did anything since my earlier attempts, and I have not filled and pressurized the tank since then.
If it makes any difference, both the rod nut and the drain hole threads are quite rusty and have been since "new" (2016 Flagstaff 12RBST obtained this year). The rod itself is fully intact and the heater has been used only to fill and test.
Thanks!
JArry is offline   Reply With Quote
Old 06-14-2016, 01:28 AM   #94
2007 WildCat 32QBBS
18CrewDually's Avatar
The anode rod is National Pipe Thread and is tapered. So when you turn it, it is tightening in the bung like a wedge. You should have some threads exposed even after tightening. Use three full wraps of Teflon tape wrapping it counter clockwise. Tighten it enough so there's no leak. If you see a drip, go a little more.
18CrewDually is offline   Reply With Quote
Old 06-14-2016, 06:32 AM   #95
JArry's Avatar
Thank you for the clarification!
Old 06-14-2016, 04:37 PM   #96
Mikegjax's Avatar
Installation instructions for the rod usually state "no more than 1 1/4 raps of Teflon tape. Idea is you must cut through enough tape to make good metal to metal contact. I usually check continuity with an omh meter after installation.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-15-2016, 06:39 AM   #97
Maybe that is why my Anode Rod is in such good shape,,, either to much Teflon tape ??? Or filtered soft water ???
Question for one of our plumbers,,,
Does it matter which way we rap out Teflon tape,,,
Clockwise or Counterclockwise ???
I vote NO !!!
Old 06-15-2016, 07:08 AM   #98
bubbles's Avatar
No. however, typically with all plumbing items where used it is installed clockwise when viewing threaded end (right hand threads). This assures the tape will not try to bunch up or unwind when item is screwed in.
Old 06-15-2016, 07:32 AM   #99
I have used many many roles of Teflon tape,,, and have never had one bunch up or unwind,,, maybe because I apply the tape very tightly ???
Thanks for your reply !!!
Old 06-15-2016, 07:33 AM   #100
nomad297's Avatar
I vote NO !!!
Plumber here. You start the tape at the end of the thread that goes into the fitting and follow the direction of the thread as you wrap up towards the larger diameter of the NPT threads. It is hard to describe it as clockwise or counterclockwise because it all depends on which way you are looking at the threads.
Bruce
anode
