Old 12-05-2020, 08:24 PM   #1
No AC power, DC OK in T21DMHW
Moved the A-frame up to the house today to begin winterizing, plugged it in, and found an electrical problem. As far as I can tell, DC power and wiring are all good. Battery is charging and DC devices all run. But there’s no AC power to any of the outlets or appliances. Checked the breakers and fuses with no luck (edit: also reset the GFI, which was tripped, with no change). Examined the wiring in the bench seat behind the panel and didn’t notice anything obvious. Converter is the factory WF-8735P from 2018. Is it possible for them to fail in this way? If so, time to look at replacements? Thanks in advance.
GM80 is offline   Reply With Quote
Old 12-05-2020, 08:30 PM   #2
World Traveler Member
abdiver's Avatar
Originally Posted by GM80 View Post
Moved the A-frame up to the house today to begin winterizing, plugged it in, and found an electrical problem. As far as I can tell, DC power and wiring are all good. Battery is charging and DC devices all run. But thereís no AC power to any of the outlets or appliances. Checked the breakers and fuses with no luck. Examined the wiring in the bench seat behind the panel and didnít notice anything obvious. Converter is the factory WF-8735P from 2018. Is it possible for them to fail in this way? If so, time to look at replacements? Thanks in advance.
Did you check your GFI by your power station, just push the button?
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 12-05-2020, 10:02 PM   #3
Thanks for asking, forgot to mention that. Yes I did. It was tripped but resetting it didn’t change the situation. It did not immediately fault again.
Old 12-06-2020, 06:20 AM   #4
Head Rambler
Since the converter is working and the GFCI reset that means that power is getting to the RV.
Is there power at the GFCI? There should be since it reset, even if maybe just on one of receptacles? If it reset and there's no power at it, then I'd suspect a bad GFCI.
Gotta go campin!
Old 12-09-2020, 02:03 AM   #5
No power in either GFCI receptacle. I'm no electrician, but also no VAC present in the wiring behind the GFCI outlet as far as my meter shows. Will unhook from shore power and swap the outlet anyway, as it's some cheap plastic crap that gives me the willies (not to mention the two different types of fasteners the factory used do hold it onto the box... one's a coarse thread wood screw). Will update. Thanks.
2019 Flagstaff T21DMHW
2014 Chevrolet Silverado 1500 5.3/3.42
Old 12-09-2020, 09:10 AM   #6
Head Rambler
If there's no power to the GFCI then it shouldn't have reset. Most all the GFCI's I've dealt with have to have power in order for the reset button to work.
Gotta go campin!
Old 12-09-2020, 09:18 AM   #7
Flybob's Avatar
How did you determine the battery is charging? Please check the power at the house outlet where you have the RV plugged in. If the circuit is protected by a GFCI in the house, it is possible that the circuit is not live. We have seen instances where two GFCIs in series do not work well. The GFCI is an electrical device and requires AC power to reset so without power pushing the reset does nothing. Start at the house outlet. Then using a meter check the RV end of the power cord. It is very likely this is not an RV issue.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-09-2020, 10:57 AM   #8
Noted, thank you. Always happy to learn something new.
How did you determine the battery is charging? Please check the power at the house outlet where you have the RV plugged in. If the circuit is protected by a GFCI in the house, it is possible that the circuit is not live. Start at the house outlet. Then using a meter check the RV end of the power cord. It is very likely this is not an RV issue.
The camper had been stored (unintentionally) since March, so power vampires had completely drained the battery. When I went to retrieve it, the power tongue jack, roof lift, and clock radio were completely inoperable. I cranked it up by hand and connected it to the house. They were still inoperable at first, but slowly came back to life and are now working fine (like the rest of the 12V gear). I have made the assumption that they're running on a now-charged battery.
The house outlet is an outdoor 30A run by an electrician last year. As far as I know, it goes directly from a dedicated 30A breaker to the outlet on the exterior wall with no GFCI involved. We used it successfully several times before March. I will also begin with a cable check as you suggested, though. Seems like a logical starting place.
Thanks for your input, folks.
Old 12-09-2020, 11:22 AM   #9
Always disconnect your battery when stored. Deep cycle batteries donít like to be fully drained.
PapaGlenn is offline   Reply With Quote
Old 12-09-2020, 01:16 PM   #10
Chances are the dead battery is still dead, and the converter is running your 12V bus. The WFCO converter will often blow the 30A battery fuse on the panel if the battery is below 10V, instead of charging the battery. That's what happened to me. Check all your fuses on the panel, and the resettable 12V circuit breaker on the underside of the left tongue beam.
By code in most areas, outside outlets have to be GFCI protected. The GFCI can be at the outlet (unlikely for 30A) or at the circuit breaker in your house panel (more likely).
The ONLY AC appliance on an A-frame that runs without DC power is the microwave. A quick check of the microwave clock tells me if I have AC power coming into the camper.
If you have AC power to the A-frame (voltage check on the power cord), then check all your circuit breakers on the panel. The left breaker is the master breaker for the AC input. But I do believe you have AC coming in because the converter is powered. Which likely leads back to a GFCI issue because the outlets are not powered.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 12-10-2020, 11:13 AM   #11
Final update, hopefully, as I have a reliable solutionÖ but I'm still not sure what's happening.
I started from the in-house breaker and worked my way through each component step by step. There is no GFCI on the outdoor 30A circuit (although there is one on an outdoor 20A installed at the same timeómaybe that's our local code?).
I discovered that if I shut off the 30A outlet at the breaker, then connect the RV, then bring the power back online, everything works fine. AC appliances ran all night with no issues.
If there's already power to the 30A outlet when I connect, though, the RV GFCI trips and there's no AC power inside (as described in the original post) ó even after resetting the GFCI and toggling the RV breakers. I have to toggle the house breaker to get the RV to "recognize" it.
Like I said, no idea what that means but I'll just connect things in the "correct" order from now on. Thanks for everyone's input.
Old 12-10-2020, 11:20 AM   #12
Flybob's Avatar
Are you sure that the house 30A circuit breaker is not a GFCI breaker?
TST Tire Monitors
2 100W solar panels
Old 12-10-2020, 11:27 AM   #13
OYO
OYO's Avatar
With your last post I'm suspicious of your 30 amp line (but I'm no expert).
Do you have a 30 amp to 15 amp adapter aka dogbone?
https://www.etrailer.com/RV-Plug-Ada...0-1530HVP.html
Just curious if the camper behaves the same using your 20 amp line.
You don't really need 30 except to run the heatpump.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is offline   Reply With Quote
Old 12-10-2020, 11:33 AM   #14
There is no test/reset button on either the breaker or the outlet. It looks like every other standard breaker in the panel. As it's a straight dedicated run between the two, I'm not sure what I could be overlooking.
Originally Posted by OYO View Post
Do you have a 30 amp to 15 amp adapter aka dogbone? Just curious if the camper behaves the same using your 20 amp line.
I do and I used it for "everything but heatpump" prior to having the 30A line installed. Will try it later to see whether the same issue is present.
Thanks folks
Old 12-10-2020, 12:17 PM   #15
Head Rambler
Sounds like the RV GFCI trips when you "plug" the power cord into the 30 amp receptacle with power applied, and then isn't actually resetting when you press the button.
Have you ever checked the receptacle to make sure the Hot and Neutral aren't switched?
Did you replace the GFCI in the RV?
Have you checked the shore power cord ends and receptacle for loose connections?
Does the blades or slots in the plug/receptacle look burnt or like they've been hot?
Gotta go campin!
power
