Old 04-16-2013, 04:13 PM   #1
no running lights ...
It had to happen today .. as we are leaving for South Carolina tomorrow ... ahhhhh.
anyways, im hoping someone can help ... the wiring in the truck was installed professionally with a Nissan plug and play wiring harness .. but i have no running lights on the trailer.
All signals work, brake lights, turn signals, 4 way flashers, and electric brakes .. but i have no running lights at all on the trailer. I checked the pigtail, cleaned both with a cloth ... inserted it in and out .. and still no running lights.
This is really not a biggie .. as we only travel during the day .. and are off the road at 4 pm at the latest ...
Any ideas would be appreciated ...
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 04-16-2013, 04:17 PM   #2
TURBS's Avatar
Check running light fuse in vehicle.
Late model units have seperate towed unit fuses from the tv.
Turbs
Old 04-16-2013, 04:17 PM   #3
d-mo
I would suspect the truck plug n play connection for the tail lights didn't make good contact.
Old 04-16-2013, 06:06 PM   #4
Trailer Wiring Diagram light plug brakes hitch 7 pin way wire brake lights connector utility boat
Check for voltage at pin 6.
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 04-16-2013, 06:12 PM   #5
Herk7769's Avatar
Check your ground connection.
Clean your Bargman plug and socket.
ID:	28155   Click image for larger version
Name:	Connector Pin Out.gif
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-16-2013, 06:13 PM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
Brake lights, turns, and 4 ways are all the same. Vet a meter and start with the plug and work from there.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-16-2013, 06:30 PM   #7
handbuilder's Avatar
I had to replace the fuse on my trailer. It is located on the driver side of the trailer, nearby the propane tanks. Running lights back on. It was the blue fuse, 20 or 25?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-16-2013, 06:31 PM   #8
Phat Phrog Stunt Crew
elind's Avatar
In my GMC there is fuses for all the trailer lights that is independent of the truck lights. I had lost my running lights on my TT and i found fuse # 25 in a fuse box under the hood was burned out. It could be as simple as that.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-19-2013, 03:08 PM   #9
elind, you are spot on with this! Once again I had no running lights but the fuses on my trailer were fine this time. I co-incidentally had appt w/dealer today for my Dometic fridge annual check up & noticed my running lights were off. He found it was the fuse in thetruck. He replaced it with a red fuse...whatever amp that is. It was seperate of the trailer & not the same as my last fuse replaced. You rock!
Old 04-19-2013, 03:12 PM   #10
TURBS's Avatar
Hey wait ! I answered this in the very first post ! Albeit for the op.......
Kids I tell ya
Turbs
Old 04-19-2013, 03:28 PM   #11
Sorry Turbs, you did too!! You always rock!!
Old 04-19-2013, 04:11 PM   #12
And sometimes he rolls.
Old 04-19-2013, 04:17 PM   #13
TURBS's Avatar
Most likely stagger.
Old 04-19-2013, 04:19 PM   #14
ko777's Avatar
Is there a charge for the annual checkup?
ko777 is offline   Reply With Quote
Old 04-19-2013, 04:25 PM   #15
TURBS's Avatar
If an oem "requires" it for warranty purposes then there should be no charge!
Old 04-19-2013, 04:36 PM   #16
Phor once, I was trying to be nice. My mistake, won't happen again.
Old 04-19-2013, 04:52 PM   #17
TURBS's Avatar
writing that one down as I will most likely hold ya to it !
