The other thing to check if you have difficulty connecting is that (for me at least) the position of the shutoff lever at the fitting on the end of the hose makes a difference. If I remember correctly, it will only connect properly if the lever is off (perpendicular to hose). If the lever is on (parallel to hose), the sleeve of the fitting will not attach. Might seem obvious you wouldn't want to connect the fitting with the valve already open, but if the main gas (at tank) is not turned on yet, it is easy to not realize the significance of the fitting shutoff.
FWIW...
Former owner of 2016 Flagstaff T12RBST A-Frame - we had a good run, but it's time for a conventional TT!
Nights camped since 2016: 370
