Been on a 10 day camping trip with our A-frame, so couldn't respond fully sooner.
1. Standing water on the roof - hard to believe if camper was/is moving during trailering and setup. If roof is latched down too tight, you might have water piled up against the seal where rear roof goes under front roof. You want roof line straight and level when folded.
- When hitched for trailering are you substantially nose low? A-frames should be trailered close to level. A-frame and tow vehicle will ride much better if close to level.
- Raise tongue to drain any standing water before setup. I automatically do this because I have a WDH to deal with the near 500lb tongue weight on my A-frame. Raise the tongue to remove the bars, lower the tongue to unhitch, than set tongue for level when camping.
- I do occasionally have an issue with standing water on forward roof against dormer hinge seal when folding down after/during a rain. Helps a lot if the camper is level side-to-side, so rain goes down side, and not onto folded side panels. I also have towels at the ready when folding down. I then use the large dish towels to pad where starboard side panel rests on port side panel window frame, and over door window frame.
- Also waiting to fold until after hitching up will drain any standing water through the tongue up/down, and moving off leveling blocks. I have done this when I needed to.
- Stabilizers are last thing to go down when setting up, and first thing to go up when hooking up/folding down. There is plenty of tongue weight to support one person in rear of camper without stabilizers, even 2 if you don't go all the way to the back.
2. Every A-frame I know has these gaps. They have never leaked for me. Some fix it with rubber gasket material, I haven't.
3. I have the twin bed model where the center can be filled in for a single king? bed. We use a modified twin bed where the center is partially filled to allow standing access and rear drawer access. Under the port bed is the Cool Cat, water pump, water filter, and a drawer for limited storage. Not a lot of extra space. Under the starboard bed is storage that we access from the outside door. If absolutely necessary, we use the inside door at the forward end of the bed.
Fred W
2019 Flagstaff T21TBHW A-frame
2022 Hyundai Palisade
