Old 10-22-2020, 06:18 PM   #1
Itching to go . . .
Moosure's Avatar
Rear Molding
I'm wondering if anyone has experience making a repair to the molding at the rear corner of their Flagstaff Aframe. After three years (stored indoors when not on the road) I just noticed that it is beginning to pull away. What did you use to "stick" it back down? How extensively did you clean out the old "stuff"? I could really use some pointers - start to finish. Thanks!
2016 4Runner
2018 T21TBHW Aframe
Moosure is offline   Reply With Quote
Old 10-23-2020, 07:54 AM   #2
MinneweeseMI's Avatar
Rear Molding
I too would like to know what to do. I kissed a tree this past weekend and broke the marker lens and just moved the rear trim a little.
I am guessing a hair dryer or heat gun to pry it off? Then a shot of construction adhesive and some clamping contraption to hold it place?
If anyone else has experience or ideas, it would help.
Thanks!
ID:	241727   Click image for larger version
Mark
Michigan
2014 a122s
2014 Tacoma Double Cab
My YouTube Channel
Days Camped 2016/2017/2018/2019: 98/106/109/73
MinneweeseMI is offline   Reply With Quote
Old 10-25-2020, 11:35 AM   #3
For the trim try using some 3M trim adhesive from an auto parts store.
chengdave is offline   Reply With Quote
Old 10-26-2020, 07:17 AM   #4
Thanks!
I did not know there was trim adhesive like that! I will give that a try.
Mark
Michigan
2014 a122s
My YouTube Channel
Old 10-27-2020, 10:15 AM   #5
That rear trim is screwed down on mine. I had a similar problem with bottom pulled out about 3/16th". Remove the center vinyl strip by simply popping it out with a small screwdriver and you will see the screws holding it down. The screw had rusted and stripped out on mine so I replaced screw with a slightly larger one and retightened and it went back into place. I don't think glue is going to hold it down because there was a fair mount of tension on mine. You may just have to simply retighten those screws in your case. If caulk was disturbed you may have to re-caulk trim after tightening screws. There might be a small screw at bottom of that center vinyl strip that you may have to remove first to allow it to be completely removed out of the way.
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 10-27-2020, 11:23 AM   #6
Originally Posted by mzak View Post
That rear trim is screwed down on mine...
Awesome! I never would have looked under that.
Thanks much!
Mark
Michigan
2014 a122s
My YouTube Channel
Old 10-27-2020, 01:18 PM   #7
Your welcome. Hope it helps solve your issue.
2012 Rockwood a124
Old 10-30-2020, 07:55 PM   #8
JArry's Avatar
I backed into something in 2016, causing a small tear in the center vinyl. I put a piece of electrical tape over it and it's still there.
2016 Flagstaff T12RBST A-Frame | 2017 Ford Escape SE AWD 2.0 Eco (starting 2021)
Nights camped in 2016: 37; 2017: 54; 2018: 47; 2019: 63; 2020: 53
JArry is offline   Reply With Quote
Old 10-31-2020, 10:13 AM   #9
I cracked a taillight in a similar manner. I didn't have any 3m Extreme tape on me and the Gorilla Duct tape isn't that good so I used a piece of Velcro tape! That stuff is so sticky! It doesn't bend and shape as well as duct tape, but it was good enough to get me home 4 years ago (and yep, it's still there and working!!)
Mark
Michigan
2014 a122s
My YouTube Channel
Old 11-02-2020, 04:31 PM   #10
mzak is dead on with how to fix/tighten the corner molding. Depending on the condition of the wood below the trim, you may have to slip in a wooden matchstick or some wooden toothpicks with some wood glue on them. Clean off the old caulking and re-caulk the edges of the trim. I noticed this happening last year, then while at a FROG rally in Williston, FL. the service speakers came around to our sites and allowed us to ask questions about repairs that we felt needed to be done. The advisors then gave us hints on how to go about doing the repairs. What a great benefit we received while at the rally.
2016 T21TBHW
2017 Ram 2500 CTD CC SB 4x4
Ortep is offline   Reply With Quote
Old 11-05-2020, 07:32 AM   #11
Originally Posted by Ortep View Post
mzak is dead on with how to fix/tighten the corner molding...
Great instructions, I had no idea.
Thanks all!
Mark
Michigan
2014 a122s
My YouTube Channel
mold
