Originally Posted by Bama Rambler
What model fridge do you have?
^^X2^^
When asking a question about a specific appliance, it is ALWAYS good to post the make/model of that appliance.
Forest River uses many different brands/models of refrigerators/water heaters/stoves/ovens across their many divisions and even within same divisions.
How are you controlling the refrigerator?
You mentioned you plug it in the night before and it gets cold then it doesn't cool at the campsite.
Did you turn the refrigerator off when leaving out on your trip and then back on at the campsite?
Are you relying on the Auto feature?
If so is your propane on so when you unplug to leave it can light on LP?
If you didn't have the propane on has the refrigerator gone into lock-out?
These may/may not apply to you depending on the refrigerator make/model.
Many A-frame trailers have 3 way refrigerators the can be run on 12v during travel. Is this an option on YOUR refrigerator?
Have you purged your gas lines?
When first opening the gas bottle valve (and you must open slowly to keep the internal excess flow device from actuating) you must let the lines purge. This is often accomplished by opening a stove burner valve and lighting. Sometimes it can take a minute or so before the air purges out and LP gas begins to flow.
We are all just guessing without some specific information.
