Old 08-18-2022, 09:10 AM   #1
Removing a RM2354 refrig
I have to remove a RM2354 refig in order to secure the drop in propane stove that has become lose due to 2 of the four plastic brackets failing.
Two questions, please describe how to remove the refrig or how to attach the stove to the top of the cabinet without removing the refrigerator.
Aframe Tom is offline   Reply With Quote
Old 08-19-2022, 02:20 PM   #2
It would help if you could post the year, make and model of your rig so that someone can help.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-19-2022, 02:37 PM   #3
bikendan's Avatar
Profile says a 2017 Rockwood A213 A-frame high wall trailer.
Moved thread to the A-frame sub-forum since this fridge and its removal will much different than other types of RVs.
Old 08-19-2022, 02:48 PM   #4
Retired Old Fart
dward51's Avatar
I know my fridge is not only screwed in at the base, but they also coated the entire base area with a polyurethane caulk/sealant. It is a bear to remove. Don't know if yours is like this, but that would be the hardest part on taking mine out.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 08-19-2022, 03:09 PM   #5
Thanks for the gentle reminder R_S. That may help!
2017 213 HW. Forest River Rockwood
Old 08-20-2022, 10:46 AM   #6
I would take the stove apart before I would try to move the fridge out. I haven't tried with the 2 burner in my 2019 T21TBHW (same as A213HW). But I did remove and reinstall the 3 burner stove in my 2014 A122 because all the cushions and hinges for the glass top came loose. Wasn't pleasant, but wasn't impossible for a non-mechanical type like me. Put in better fastenings when I reinstalled.
Fred W
2019 Flagstaff T21TBHW A-frame
2022 Hyundai Palisade
Old 08-20-2022, 03:57 PM   #7
Removing a fridge in order to replace fasteners on a dometic 3 burner stove
Thank you for the reply. I had not thought about taking the stove apart. Good call in replacing the fasteners with better quality. The fasteners that failed are very cheap, just like the replacement that I purchased at a hwy robbery price of over eighty dollars!
