Old 05-09-2021, 08:48 PM   #1
Replacement water valve source?
Looking for recommendations on where to buy the white plastic valves used for water supply lines, specifically the bypass valve used to fill the lines with antifreeze.
Winterized our A213HW for the first time in February in advance of the crazy winter storm that hit texas. I used the bypass valve thatís underneath, near the water tank that others have described to fill the lines with antifreeze, worked great. De-winterized and went on a trip over spring break. I must have forgotten to turn the valve back and weirdly our fresh water tank started to fill while hooked up to city water. I only noticed this when water started to dribble out the fresh water fill openingÖ Turned the valve the correct direction, emptied the tank and went home at the end of the week. Tested everything this afternoon and while I donít seem to have the tank filling problem, the bypass valve is leaking. Did a quick search and am not seeing the oem type anywhere. Is there something at Home Depot that will easily substitute? Itís only a drip, but I donít want to waste water or create mud.
Any ideas welcome- thanks!
Archibella is offline   Reply With Quote
Old 05-09-2021, 11:10 PM   #2
https://www.amazon.com/Elkhart-28910...dp/B00R9GC6PA/
Here's a brass version that would require hose barb adapters to connect to it:
NavyLCDR is offline   Reply With Quote
Old 05-10-2021, 01:13 AM   #3
rvpartscountry has pretty good prices. They price matched a couple parts for me but didn't on one part. They were very helpful and easy to deal with.
https://www.rvpartscountry.com/Sea-T...-Valve-12.html
2020 F-250 XLT
2020 Salem Cruise Lite 241QBXL
KE8SDQ
Ryan-OH is offline   Reply With Quote
replacement, valve, water
