Old 04-08-2018, 04:29 PM   #1
steve02bat's Avatar
Roof actuator replacement
Forest River sent a replacement part for the roof actuator at no charge. Model a214hw roof actuator failed after first season. Easy to replace. 1 nut at the top and another at the bottom, cut the wire and the old one is gone. Use the same brackets for the new actuator. The main difference is there is now a Jack to plug into the Actuator motor. It's the same one used for zamp solar. Rockwood sent me the part. I just pulled out the wires through the hole on the bottom bracket where the actuator is attached. It is connected under the bed and easy to find. I didn't do a very fancy job installing the new zamp outlet. I just left it hanging, which is Rockwood told me to do. Everything works.Click image for larger version
ID:	167571Click image for larger version
ID:	167572Click image for larger version
steve02bat is offline   Reply With Quote
Old 04-08-2018, 04:57 PM   #2
OYO
I find this amusing. They've decided to make it easier to replace the actuators when (not if) they fail.
On another note: I'm convinced it's all about waterproofing. On my 3rd one I sprayed the motor with flexseal and made a grommet like thing to keep the water from running down the shaft into the motor housing.
No issues over a year later.
OYO is offline   Reply With Quote
Old 04-08-2018, 06:54 PM   #3
Yep, it looks like it will be easier to replace BUT now you have "daggling" wires to get caught on a stray branch, flying road debris etc. at least for those of us who have the "older" models. I would hope that the new units coming off the production line have a "cleaner" look with NO wires to get caught on debris.
Ortep is offline   Reply With Quote
Old 04-08-2018, 09:14 PM   #4
MontyPP's Avatar
If and when I have to do mine. I'm going to make a braket for the connector to sit in or on. I snag my belt knife holster on that arm every-now-en'again as it is
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 04-09-2018, 02:32 PM   #5
I removed the cable hookup and replaced it with the plug since I never used the cable.
cpttimerstraint is offline   Reply With Quote
Old 04-11-2018, 09:11 AM   #6
Called my dealer yesterday to get a replacement assembly under warranty. I remember when we bought the camper, the motor hummed right along lifting and lowering. When setting up last weekend, we had to "help" to lift the roof. Then when we returned home, the assist stopped after raising the roof about a foot. I lowered it and disconnected the assembly and raised the roof by hand. The assist is a nice concept but poorly implemented.
2014 Nissan Pathfinder AWD w/Tow pkg
2017 Flagstaff T21TBHW
traveling.geocacher is offline   Reply With Quote
Old 04-11-2018, 09:35 AM   #7
If they give you any hassle, just contact Tim at Forest River and he will get you one out quick. Once you deal with Tim, you will realize that everything the dealers tell you about warranty service is complete lies. He is easy to deal with and ships parts fast.
Mods, can we make a sticky with Tim's contact info?
Old 04-11-2018, 09:41 AM   #8
cpttimerstraint, I appreciate the info. Can you PM me Tim's info in the event I need it. The dealer already ordered it but the hassle is I need to take the camper to them to install under warranty. On the bright side, it will give me an opportunity to get some other stuff looked at.
Old 04-11-2018, 01:53 PM   #9
Tim Brumbaugh
Warranty Administrator
Rockwood & Flagstaff
Forest River Inc.
Phone: 574.642.8944
tbrumbaugh@forestriverinc.com
Old 04-11-2018, 01:56 PM   #10
Thank you, I'll put that in my camping contacts folder.
Old 04-11-2018, 02:30 PM   #11
steve02bat's Avatar
That's a good idea
Old 05-10-2018, 09:25 PM   #12
I drilled it out and made it look like it had always been there. It was aggravating at first but I am glad it was the plug in and not the hardwired mine came with because it will be easier to swap out when it craps out again. And yes I fully expect it will!
tlspencer is offline   Reply With Quote
Old 06-09-2018, 01:52 PM   #13
steve02bat's Avatar
I haven't heard about any of the new actuators failing. At some point last year they started with a new model actuator . That is what they sent me as a replacement anyway and so far seems much better.
Old 06-28-2018, 07:20 PM   #14
Exclamation New Warranty administrator
Tim Brumbaugh
Forest River Inc.
Phone: 574.642.8944
There is a new Warranty Administrator , her name is Rayna Dimitross
Same phone # 574-642-8944. She was great, sent a new actuator when I called her to tell her ours was dead. Also when you call be sure to have the last 7 #’s of your VIN to prove which unit you have.
LafIN is offline   Reply With Quote
Old 06-29-2018, 05:13 AM   #15
Can some post pictures of the old and new actuators please?
Midnight Rider is offline   Reply With Quote
Old 06-29-2018, 01:04 PM   #16
Had mine replaced a few weeks ago by Rayna, looks pretty much the same as the old one that when into the trash. Installed new one and ran the roof up and down a few times and then took it off and stored it in camper. I can raise and lower the roof a lot faster by hand.
2021 Apex Nano 191RBS OFF GRID
2017 Chevy Colorado Z71 4x4 3.6 L
backpacker3 is offline   Reply With Quote
Old 02-18-2019, 10:51 AM   #17
Good morning,
I am on number 5 actuator.
I drilled a 3/4 hole in the side of trailer and used two screws to secure it.
It took only about 20 minutes and it is now set up for the new style, that will fail again I am sure. Now if and when it fails I just need an adjustable wrench to remove and unplug.
I hate to be a negative nelly but experience s the best teacher.
steve2000xj is offline   Reply With Quote
Old 03-13-2019, 06:58 PM   #18
Thanks for the above name and number. My actuator went out and I have a new one being sent over.
Old 03-21-2019, 08:45 PM   #19
On actuator #3
First 2 went out in first year. The last one they sent was a different design.
NormTn is offline   Reply With Quote
Old 04-11-2019, 01:52 PM   #20
I have been following this thread and others on the roof actuator. I have decided to go with gas springs. I tried to order from Hatch lift as was suggested and just my luck they are out of stock on the springs that I need. So I found a site “Liftsupport depot” they had the springs and brackets in stock and with free shipping so I placed the order. And here is a link on what I ordered.
Gas Spring
https://www.liftsupportsdepot.com/li...-lift-support/
10mm Ball Mount
https://www.liftsupportsdepot.com/qt...bracket-black/
I hope the install goes well
Thanks for all the info and hard work on this problem over the last few years
Gerbie53 is offline   Reply With Quote
replacement, roo, roof
