Old 05-09-2015, 06:17 PM   #1
A-Frame Don's Avatar
Question Switch for Outside Stereo Speaker
Has anyone added a switch to turn off the outside speaker? I find if the inside two speakers are balanced end to end, the outside speaker is too loud. I would like to turn it off, as I'm not likely to use if very often. I still want the option to use it. I think the outside speaker is connected to the one inside, under the bed--correct?
2015 Rockwood A192HW
2011 KIA Sorento 6Cyl
A-Frame Don is offline   Reply With Quote
Old 05-09-2015, 06:29 PM   #2
Mowgli64's Avatar
On most stereos you can choose between A or B or both A&B on for speakers. One would be inside one would be outside.
2015 Wildwood X-Lite 271RBXL
2019 Ford F350 CrewCab Diesel
(2013 Ford F150 Crewcab Ecoboost traded)
Mowgli64 is offline   Reply With Quote
Old 05-09-2015, 06:41 PM   #3
gashog's Avatar
Mine has A - B - C on the Radio/DVD player: "A" for living area, "B" for bedroom and "C" are the outside speakers. Can activate them in any combination.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 05-09-2015, 09:16 PM   #4
N3XG's Avatar
My A122S is controlled with the balance. The Fader controls the mix inside while the balance controls the mix between in and out. I move the balance all the way inside whenever I'm finished with outdoor music.
2012 GMC Canyon
2015 Rockwood A122S
N3XG / WQDV803
N3XG is offline   Reply With Quote
Old 05-09-2015, 09:23 PM   #5
RSchleder's Avatar
Our new Wildcat MAXX has 3 buttons 1/3rd the way down the face plate. Each bottom turns on or off each of the 3 sets of sparkers. When you push each button, the readout on the radio/DVD players shows which speakers you turned on/off.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-10-2015, 08:57 AM   #6
Yup...on my radio, use the balance feature to put all the sound inside the trailer.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-10-2015, 03:08 PM   #7
x2
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 05-10-2015, 06:04 PM   #8
The radio/stereo is a Kenwood model KDC-152 and being a car stereo it's designed to have speakers in pairs, not an odd number such as three. For example--speaker #1-front dinette bench, #2-below bed, #3-outside.
Using the Balance function as follows:
Balance adjusted, L-15.....#2 speaker
" " R-15.....#3 "
" " 0 .....#1, #2 & #3 speakers
Using the Fader function as follows:
Fader adjusted, Front-15....#2 & #3 speakers
" " , Rear-15.....#1 speaker
" " , 0 ......#1-#2-#3 "
Nohow can I figure out to balance speakers #1 and #2, which are inside, and the outside #3 off. If I have an off switch for outside speaker #3, the inside ones could be balanced in the stereo mode.
Is my old mind missing something here or am I on the right track.
Old 05-11-2015, 07:59 AM   #9
Mowgli64's Avatar
You may be able to remove radio and switch the #1 & #3 speaker wires so you could fade to front for #1 & #2 and fade to rear for #3.
I have not removed a newer RV stereo so am not positive on that.
Old 05-13-2015, 09:48 AM   #10
On a car stereo, balance is between left and right, and fade is between front and rear speakers. It sounds like your RV is wired with one (left or right) channel inside & the other channel outside, which leaves you listening to only the L or R channel.
If that is so, you need to switch the speaker wires around on the back of the radio, so that inside is connected as front L&R, and outside is connected as rear L&R. That way you will hear both channels, and inside/outside will be controlled by "fade".
johntaylor is offline   Reply With Quote
Old 05-17-2015, 06:44 AM   #11
Pyle Home PVCS2 In-Wall A/B Source Selector Switch Control https://www.amazon.com/dp/B007JV6F34..._m8hwvb1SPSR1Y
2011 A-122
rawlus is offline   Reply With Quote
