Old 08-02-2021, 10:32 PM   #1
Water filter housing is leaking
I have a 2021 Rockwood A122S pop-uo. The unit did not come with a water filter. I camped several times without a water filter, and the pump worked fine without a leak.
I unscrewed the housing for the first time (it was very tight) and put in my filter. I screwed it back in. Whenever I turn on the water pump, water now shoots out of the lowest thread of the housing, as if it is not tight enough (I hand tightened it sufficiently). I have tried loosening and re-tightening several times to no avail. The thread appears intact and the o-ring on the housing is still there. Am I missing another o-ring on the base of the threads? Or am I doing something wrong? I've pictured the housing in question.
juiceman is offline   Reply With Quote
Old 08-03-2021, 06:18 AM   #2
OYO
OYO's Avatar
I'd say it might be either the filter isn't seated right in the canister or it's the wrong filter.
Here's what I use: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is offline   Reply With Quote
Old 08-03-2021, 06:40 AM   #3
That's a terrible o-ring design.
Look into the head to make sure there's nothing like a small piece of trash in the o-ring area that would keep it from sealing.
Try taking some lube (pool or personal) and lube the top of the canister and the o-ring and then tighten it into the head. You may wind up needing a wrench to get the canister to seal properly.
Gotta go campin!
Old 08-03-2021, 06:53 AM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Try reinstalling with out the filter and see if it leaks. If not then the filter maybe the issue. Also id you get a wrench to use on the filer? Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-52
Old 08-03-2021, 07:09 AM   #5
Kanadian Kamper
kenandterry's Avatar
I agree with RJD above here. ^^^^^^
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 08-03-2021, 07:16 AM   #6
Just Tryin' to Help
cboss's Avatar
Any chance it got cracked at the threads when you removed it.
Many of us have bypassed the onboard filter and just use an external filer on the city water hose.
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is offline   Reply With Quote
Old 08-03-2021, 07:31 AM   #7
I had the same issue. Plumbers grease on the o-ring was the cure.
2019 Rockwood MiniLite 2104S
2017 F150 3.5 EcoBoost 10 spd 4x4
SmittyCorp is offline   Reply With Quote
Old 08-03-2021, 09:04 AM   #8
OYO
OYO's Avatar
The OP stated: "I camped several times without a water filter, and the pump worked fine without a leak."
Glad I'm not the only one with reading comprehension issues.
Craig
Old 08-03-2021, 10:32 AM   #9
Just the act of opening the housing and reclosing it with the same filter caused mine to leak. Plumbers grease fixed it. Not a reading comprehension problem.
Old 08-03-2021, 10:47 AM   #10
I'll add one more thing to look for... since you mentioned it was tough to remove, you 'may' have cracked the canister especially since you say the water is spraying out near the bottom thread. Inspect the canister closely. A crack may be hard to see but it could spread when screwed on.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 08-04-2021, 08:09 AM   #11
I felt the threads on the both the male and female part of the housing and they all feel fine. I wanted to add a filter because I do a lot of boondocking, but now I regret it.
Old 08-04-2021, 08:09 AM   #12
Thanks, I will try that.
Old 08-04-2021, 08:23 AM   #13
nomad297's Avatar
“Plumber’s grease” is not necessarily what you need. For o-rings, you must use pure silicone grease. Some pure silicone grease may be labeled as “Plumbers grease”, and that would be fine to use, but most “Plumber’s grease” I have come across is not pure silicone. Read the label to make sure you are using pure silicone grease.
Bruce
Old 08-04-2021, 08:36 AM   #14
Bruce
Thank you. Side note: doesn’t it look like the housing is missing a big o ring or flat rubber ring at the base of the threads? Lubricant on its own seems like it wouldn’t do the job, but I also am an amateur, so just guessing.
Old 08-04-2021, 08:41 AM   #15
nomad297's Avatar
No. That single o-ring is all you need. What can happen when you tighten a vessel sealed at the top with a non-lubricated o-ring is, the dry o-ring will grab at some point. Then, as you continue to twist, the o-ring remains stationary and it can stretch or “bunch-up” making the seal uneven, causing a leak.
Bruce
Old 08-04-2021, 08:41 AM   #16
No.
The seal (black o-ring) is at the top of the canister above the threads.
If that seals as it should, no liquid would get down to the bottom of the threads unless there is a crack in the canister.
Old 08-07-2021, 11:41 AM   #17
Villagerjjm's Avatar
What nomad297 said but one additional comment. The synthetic grease I buy is food safe…. Good from -40 degrees F to 400 degrees F and is dielectric.
Villagerjjm is offline   Reply With Quote
Old 08-07-2021, 12:48 PM   #18
50 Year, 12 RV's
Johnfort's Avatar
Many of us got tired of dealing with filter leaks in hard to get at locations and simply plumbed the filter out and removed it. Then use an external inline filter for half the cost and none of the hassle.
2021 Rockwood 2511S (On order)
2018 Rockwood 2304KS
2020 GMC 1500 6.2L
Johnfort is offline   Reply With Quote
Old 08-14-2021, 10:25 AM   #19
Same thing happened to me when I replaced the filter. Could only find the correct size filter from one company.
It seems that the original replacement I got was 3/8” longer than the OEM that came with my 214HW
Part # F100035511 -- water filter-- 5" Water Pur Company.
Roy
royboy334 is offline   Reply With Quote
Old 08-14-2021, 11:13 AM   #20
Lee-C's Avatar
IF filter housing was overtightened originally, the housing was not cracked upon removal, and the correct replacement filter was installed, then there is also the possibility that the o-ring seal was "flat spotted". Recommend checking the o-ring for full roundness (not referring to the housing diameter). As recommend above, would use a good o-ring lube upon reassembly. Good luck.
Lee-C is offline   Reply With Quote
leak, water, water filter
