The fan is fine, the battery not so much.
The fan draws .25 Amp per hour that means ~6 Amp per day. The battery has a nominal AH rating of 65 of which is less than half available from this type of hybrid battery. When it dies buy yourself a good 12 Volt "true" deep cycle battery.
To keep it simple you could call Volt the type of fuel and Amp the amount of fuel.
If the battery only had to supply power for this fan it could run for a couple days but since the fridge, CO/LPG Alarm and other parasitic loads are also connected I suspect that your battery will be toast after a day.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
