It takes longer to freeze
It takes a couple of days without getting above freezing to lock things up. The coldest temp we camped in was -5F and the water lines to the kitchen sink froze. They started flowing when we opened the cabinets letting the warm air in.
When it is cold the most critical resources are power and propane. As mentioned earlier you can haul water and if it starts out warm you can use it a bit longer. Water heaters are not freeze tolerant - they are made of metal and are mounted outside.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
