Winterizing questions
I have a 2016 Forest River Viking Legend V12RB A-Frame that I bought used this summer and will be winterizing in a couple of weeks.
I have read through all of the winterizing procedures and tips found on this forum and other places on the internet. I understand all the basic winterizing principles with the low point drains, bypassing the hot water heater, removing the sacrificial anode rod, blowing compressed air through the city water connection, and then pumping RV antifreeze through the lines until it is pink through all the faucets, etc. However, I still have a couple of questions.
The 27 gallon fresh water tank under the trailer has a bulge in the bottom, while the outlet is on the side. Therefore the fresh water tank never completely empties (who designs these things?). I would assume there probably is 2-3 gallons of water left in the bottom. I would assume it is safe to leave the drain open and just let the 2-3 gallons of water stay in the tank and freeze, as there is plenty of expansion space and that there will be no harm.
The line from the fresh water tank and the city water connection runs in a hidden space behind the sink area. How does the city water connection connect into the fresh water line from the tank? Is there any thing that has to be done here to winterize the city water connection?
I see talk of a water filter. I don't "think" have have a water filter anywhere. At least it is not in plain sight. What I do have is a small metal screen filter in a small, clear, bowl right before the pump. I would assume since this is just a metal screen filter, that it can stay in line and the RV antifreeze should not harm it.
What I do have, I think, is for a place to suck RV antifreeze directly from the jug, is a 3 way valve with a short piece of hose on it immediately before the screen and pump. Seems kind of convenient, as I can place the jug on the floor of this space and suck right out of the jug.
Finally, the sink drain. On the underside of the sink is a bowl looking thing, but is not a normal p-trap like in a house. Is this some sort of compact trap of some kind? My thought is to initially take the shop vac to it to empty of any water, and when pink comes through the faucet, it will fill this little bowl.
Any thing that I missed?
2016 Coachmen Viking Legend 12RB A-Frame
2015 Jeep Grand Cherokee Summit w/Tow package
