Originally Posted by dpmatti
Can any one give me some tips or instructions on winterizing a rock wood A122 camper
very easy to winterize, open seat near hot water heater and engage bypass. valves, drain hot water heater, buy and hookup bypass hose near the water filter under sink, put hose into red antifreeze. turn on water pump and suction the antifreeze i to the few feet of lines remaining after bypassing the water heater, once you have the fluid in the rest of the lines (run sink hot and cold, run outside shower) you can then pull up the floor drain T valves and you’re good.
