Absolutely! You should get one. I also have 2018 4Runner and trust me you need the WDH. Otherwise your front will be hovering off the ground!! I saw a stock TRD Tacoma (which is basically a 4Runner truck) well the front end was so high, I doubt that guy was getting any traction. Very dangerous. I have a 16BHS WOLFPUP, 3200 dry, I also added a Bilstein 6122 /5150 suspension and kept the OEM coils in the rear, I was tempted to upgrade to the medium dobinson coil which is a bit stiffer than the OEM but the same height as the OEM (I did a 1.75” lift ). I’m still wondering if I should get the upgraded coils or put airbags in.
I can say with the WDH it’s droves nice and flat, and the 4 pt sway keeps the entire thing glued to the road.
I went with the equalizer brand 10k hitch. I think I posted a picture on here of my rig in one of the posts.
http://www.forestriverforums.com/for...ml#post1963592
