Old 10-29-2017, 05:31 AM   #1
marinerjoe's Avatar
A non-propane heating alternative?
I just saw this pop up in my Facebook feed and was wondering if anyone else has checked it out. If this could be used in a camper when plugged in to the campground electric, itíd save quite a bit on propane use.
Wall Mounted Panel Heaters | Best Wall Mounted Space Heater | Wall Mount Room Space Heater
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 10-29-2017, 08:12 AM   #2
marinerjoe's Avatar
It looks like itíll fit and should work pretty well. Also, theyíve got a 15% off offer through Halloween and they offer free shipping.
Iíll let yíall know how it goes. At only a 4 amp draw, I should be able to test it out plugged in to my house (no 30 amp outlet - yet).
Joe
Old 10-29-2017, 09:19 AM   #3
Jperry's Avatar
Thanks!
I ordered one as well. Will test it in my bathroom at home first and also let you know how well it works!
Jperry is offline   Reply With Quote
Old 10-29-2017, 09:34 AM   #4
These appear very expensive for just 475 watts. $140 for the plug in model.
This one's almost twice the heat (750 watts) for 1/4 the cost ($30).
https://www.vornado.com/shop/heaters...ersonal-heater
Most "whole room" plug-in heaters are 1500 watts.
And claiming "high efficiency" is BS. In a heater, ALL the power is converted to heat - 100% efficiency.
Also, you'll probably find that 475 watts isn't going to do much, unless you're camping in very mild weather.
2011 Traverse LT, 3.6L, FWD
Old 10-29-2017, 12:10 PM   #5
Wink
Have a sunbeam ceramic heater than has no fan---keeps our 34.5 travel trailer warm.
Bought at Canadian Tire.
ruggets is offline   Reply With Quote
Old 10-29-2017, 12:39 PM   #6
RudysWorld's Avatar
Some people on the forum have used electric wall heaters effectively, I have not. Total depth of unit, amps unit would draw and available outlets to plug into would be the things I would look for. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 10-29-2017, 12:40 PM   #7
Have this heater in Rockwood 27' Ultra-lite. 3 voltage settings- huge savings supplementing propane usage.
Caframo Limited 9206CABBX True North Heater
$78.82
Amazon.com
Free shipping
eromenok is offline   Reply With Quote
Old 10-29-2017, 12:44 PM   #8
The Newsoms's Avatar
My dad pointed out one time that my hair dryer was 1500 watts.
The Newsoms is offline   Reply With Quote
Old 10-29-2017, 01:01 PM   #9
$78.82
Amazon.com
Free shipping
I'm guessing you meant 3 "wattage" or "power" settings, not voltage. It's all 110VAC.
Spec sheet says 600W, 900W and 1500W. So about 5.5amps, 8.1 amps, and 13.6 amps. Plus a little for the fan.
None of these home models are greater than 1500W, because they'd pull more amps than 15amp home circuit can handle.
Old 10-29-2017, 01:09 PM   #10
In my 40' 5th wheel, I use two 1500 watt (15 amps)space heaters and the electric fireplace abd can keep the rig at a 45 degree temp difference from the outside temp. Rather use the parks electricity than my propane (an RV propane furnace is about 60% efficient whereas with an electric heater is 100%
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 10-29-2017, 01:10 PM   #11
I canít seem to find link where itís 15% off and free shipping. You wanna post link ?
Decon Blue is offline   Reply With Quote
Old 10-29-2017, 02:00 PM   #12
Heating Options
Just a little word of warning...if you're in weather that is below freezing, the propane furnace is the means of heating the underbelly where the water lines are located, right? Gotta keep that warm so I wouldn't eliminate the propane heater, just supplement it like we do. We're full timers and use the electric fireplace in the front living room and an electric space heater in the bedroom. Keeps us toasty and the propane furnace still runs enough to keep the underbelly warm.
Bobh62 is offline   Reply With Quote
Old 10-29-2017, 02:07 PM   #13
Stand corrected.
Old 10-29-2017, 02:22 PM   #14
SailorSam20500's Avatar
We use a small 3 setting, oscillating heater that used to be under my desk at work. Leave that in the big room. If it is on the colder side, I bought a 250 watt "desktop" unit at Menards that we plug into the bedroom or bath to supplement. The mini unit is currently on sale for $8.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 10-29-2017, 02:31 PM   #15
jtesta1's Avatar
U238 in a coffee can.
jtesta1 is offline   Reply With Quote
Old 10-29-2017, 02:38 PM   #16
glsimms's Avatar
This what we use as well. I keep the thermo on the furnace at 68 and let the electric heater to take most of the chill out. The thermo rarely kicks on.
One thing no one has mentioned about the wall heater is, I would be concerned about mounting anything on the walls considering how thin RV walls are.
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
Old 10-29-2017, 02:42 PM   #17
marinerjoe's Avatar
I went to their website and viewed it in non-mobile mode. Thereís a banner at the top of the page that directs folks here: Envi Panel Heater Seasonal Sale
Shhhh, the code for 15% off is BOO1715. Donít tell anybody.
Joe
Joe
Old 10-29-2017, 03:00 PM   #18
Propane heating alternative
My wife and I have wintered in Savannah, Ga for ten years. Weíve used two edenpure heaters in our Flagstaff 831RLBSS, one in bedroom, one in living area. If itís forecast to drop below freezing, we let a faucet drip. Have had no problems at all.
randy1946 is offline   Reply With Quote
Old 10-29-2017, 03:02 PM   #19
You need a lead coffee can...
Al
Old 10-29-2017, 03:14 PM   #20
We use a 1500 watt electric convection heater when plugged into shore power. No noise. (underbelly is not heated)
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
heating, propane
