11-07-2016, 01:34 AM
#41
Originally Posted by Keisling
I run one at a time but for some reason, one tank ALWAYS runs out in the middle of the night and I have to go out and switch it over at 3AM.
x2 middle of the night every time
11-07-2016, 06:13 AM
#42
I run one at a time until it gets low. Then I open both and check it daily to see when it jumps over to the other tank. That way I never worry about going outside at 3AM, and I don't worry about running out.
I also bought a scale so that I can check how much is in the tank that I'm using. I REALLY do not want to get caught without propane.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
11-07-2016, 11:16 AM
#43
BMullins46
I feel your pain we had that happen a couple years ago, only the outside temp was below freezing. Our trailer has an automatic switchover between the two bottles, the big trick is to ALWAYS check your bottles BEFORE you leave on a trip. There is an indicator on the top of the switchover valve which indicates that the bottle selected has gas or is empty. I always loosen the hold down bar and manually lift the nonselected bottle to determine if it is full or empty. Another choice for you would be to carry a 5 gallon bottle of propane in your pickup for your outside cooking and as a spare for the trailer.
11-07-2016, 11:37 AM
#44
Originally Posted by johng4706
I used to run two and have run out of gas twice. I'm thinking of putting a small piece of clear plastic on my opaque tank covers to monitor the auto change over.
I now only run one. It's a lot easier to have something to switch over to than having to find someplace to refill the tanks.
I have also gone to a 1500w heater. It keeps the TT a comfortable temp. I save on propane and use the CG's electricity. I would guess 60% of my propane is used for HW, 20% refrigerator and 20% for cooking.
Here's what I did to the cover on my Roo. You can't open the top with the front bunk folded out. (sorry for out of focus on a couple.)
I used a small piece of plexiglass from HD. Be careful when cutting and drilling it; it cracks easily.
2011 Traverse LT, 3.6L, FWD
11-08-2016, 07:52 AM
#45
Went and got propane yesterday evening at the Uhaul. $24 for both bottles. After I hooked up the full bottles and turned on one of the valves, I could hear, smell, and feel a pretty good leak coming from where the hose connects to the regulator for not one, but BOTH bottles. Unfortunately, since it was pitch black already (thank you, fall time change), I'm going to have to look into that issue now this afternoon. :sigh:
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
11-08-2016, 09:23 AM
#46
I, for one, always run both bottles open. I also have a auto switch over regulator with an empty tank indicator. I just check the indicator every few days. I never have to get up at 3am to switch over, and I've never run out unexpectedly. If you don't have an auto switch over, or an indicator, or can't see it because of a cover, FIX IT😉.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-08-2016, 06:03 PM
#47
Oddly enough, I went out there to fix the leaks tonight and nada. Even did the soapy water test on all the connections. That's the first time I've ever had something fix itself when I wasn't looking
:confounded:
11-08-2016, 06:30 PM
#48
If your bottle cover was turned around the top door cover wound not open and break off when the little hold done screws loosen up going down the road! Youroo! !
11-08-2016, 07:05 PM
#49
Rockfordroo,
Thanks. That's exactly what I want to do. I have two 30's and the cover is difficult to remove.
Having a viewing port. Makes a whole lot of sense.
11-09-2016, 01:12 PM
#50
We keep both opened but also have always had an auto switching regulator. The lever on the regulator is always pointing to the tank being used. Once that tank is empty the indicator shows red and it switches over automatically. As I regularly check the tanks, once it is red I switch the lever to point to the new tank and turn the empty tank off until I refill it.
2017 Surveyor 245BHS
2011 F250 6.2L Crew SB 4X4
11-09-2016, 01:44 PM
#51
Georgia Rally Coordinator
One tank open only. Have gauge on them and can pretty well determine when to switch over. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-13-2016, 11:53 AM
#52
Both of my bottles stay open all the time. When one is empty the gauge turns to red and when both have gas it is green
11-13-2016, 12:29 PM
#53
No matter how you do it, if you don't check them periodically, you'll wake up freezing.
11-13-2016, 01:11 PM
#54
I have auto changeover on both trailers. On the sunset trail the 20 pounders have gauges, I bought the bottles from Sam's Club for a good price. I leave them both open.
On the Windjammer I have 30 pounders and haven't found bottles with gauges but I still leave them both open.
I live in my trailers for work and keep 2 extra full bottles chained to the trailer tongue with the safety chains and a lock for whichever trailer I'm in. If I'm just taking the wife camping for a few days I just make sure the bottles are full.
I have 2-30 pounders in the back of my truck right now that I need to get filled before I make the drive back north in a few hours.
I slacked off the other day and didn't replace the one empty tank on the Windjammer. Boss asked if I wanted to work over, said not if I wasn't needed, I was wore out. He said ok. Got to trailer and turned heat on, it ran for about 20 minutes and quit, out of gas. Luckily I got to change the tanks out in the daytime instead of the dark (which I would have had to do if I worked over).
If I change out the empty one when I should there's no problem.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
11-13-2016, 01:31 PM
#55
It's like checking the air in your tires.
11-13-2016, 03:11 PM
#56
That's what my TPMS is for. Wish there was an inexpensive device to transmit tank volume or when the auto valve switches over. My tank covers are difficult to remove to check.
I'm going to cut a viewing window in the cover with a clear plastic window so I won't have to remove cover to check auto valve in the future.
11-13-2016, 03:49 PM
#57
We have an auto switch over, but I still only turn one tank on at a time. Too lazy and with CRS, wouldn't remember to look.
11-13-2016, 04:12 PM
#58
Ask and ye shall receive......
Under $30 bucks
https://tvlintl.myshopify.com/produc...e-model-tvl218
11-13-2016, 04:51 PM
#59
Originally Posted by glsimms
That is interesting. and I am a gadget freak. May order one for the house, but it wouldn't work for my 30 lb bottles nor apparently any bottles screwed down like on many RV's.
2011 Flagstaff 831 RLBSS
11-13-2016, 04:57 PM
#60
My thoughts also. I have two 30's and have them screwed down tight.
