Old 11-06-2016, 08:58 AM   #1
Both bottles at once or singularly?
Family and I are sitting here at 7:30 am. It's a balmy 50' outside and 65' in the camper.
All of a sudden the WH won't light and the furnace only blows cold air. Guess I'm out of propane.
I've got dual bottles and both valves have always been open. Sure would be nice if I could run outside and open the second bottle for some heat.
So, let's hear it. Do y'all run both bottles at once, or manually switch to the second when one runs out, and get the empty filled while running the second so that you've always got propane?
The downside of doing it that way is the inconvenience of running outside, perhaps in the middle of the cold night, when one runs dry. Of course it's also inconvenient sitting here adding layers as the camper cools down and really wanting a shower.
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 11-06-2016, 09:02 AM   #2
wmtire's Avatar
You'll find some campers do it one way or the other, for the reasons you already stated.
Depending how far you are away from a propane refilling station, this thread may help:
http://www.forestriverforums.com/for...day-76719.html
2011 Flagstaff 831 RLBSS
If fridge is the shortened form of refrigerator, where did that "d" come from?
Old 11-06-2016, 09:03 AM   #3
heavynlori's Avatar
Have a small electric heater as backup and switch your water heater to electric so you can shower
We only open one at a time to avoid running both out at the worst time
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 11-06-2016, 09:05 AM   #4
B and B's Avatar
One at a time, all 5 trailers I owned the same way.
Old 11-06-2016, 09:07 AM   #5
Wobbles's Avatar
I run one bottle at a time. It only takes a few minutes to change over to the other bottle. The furnace recovers pretty quickly and I know that I need to get a re-fill when I return.
Beats being SOL until you can find an open dealer to re-fill. Depending on location and many other issues having to wait may be a loser.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 11-06-2016, 09:08 AM   #6
HONDAMAN174's Avatar
We keep both open and when one switches to another then I just keep that info in the back of my mind. unless I just refilled cause then I know we are not emptying one. That would have been a lot of propane to go through. Might want to check your hoses for a possible leak or change your tank checking schedule.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 11-06-2016, 09:08 AM   #7
wmtire's Avatar
If you do have a water heater with an electric heating element, you can use that to heat your water.....as long as you are also connected to a form of 120 volt AC shore power (which is unknown at this point if you can use the electric heating element or an electric heater)
This thread may help if you have the Suburban
http://www.forestriverforums.com/for...tml#post327988
Old 11-06-2016, 09:12 AM   #8
Keisling's Avatar
I run one at a time but for some reason, one tank ALWAYS runs out in the middle of the night and I have to go out and switch it over at 3AM.
-Dave
2014 Wildcat 312BHX
2015 RAM 2500 Mega Cab 6.7 Cummins Turbo Diesel
Keisling is offline   Reply With Quote
Old 11-06-2016, 09:18 AM   #9
I look at this the same as having a main and reserve fuel tank on at the same time, be it truck or aircraft, and run out of fuel! In your RV you can walk around and turn on the other, Good luck on the other 2! Youroo! !
Old 11-06-2016, 09:20 AM   #10
How do you know when it switches over to the second tank?
Just to fill in missing information, I have the Suburban gas-only model. I started with new propane tanks (presumably full) in April and have made it this long before running out. I am currently on full hookups so could run an electric heater if I had one. Guess I'll add that to the shopping list.
Old 11-06-2016, 09:24 AM   #11
I use one at a time. Having to switch at 3am beats running out and having nothing to switch to.
Singular use always allows you to run completely empty without an inconvenience. Running dual, you run the risk of running empty with no backup or "guessing" when they're empty and refilling when they still had some in them.
325BH is offline   Reply With Quote
Old 11-06-2016, 09:39 AM   #12
Another one-at-a-time user. This is the first camper I have had that had the auto-switch over capability. As a result, I don't fully trust it.
In reality, it takes us more than a year to run through a tank with our little A-frame. Gives plenty of time to take the empty off and get it refilled. And it gives plenty of time between 3AM trips to do the manual switch over.
Fred W
2014 Rockwood A122 A-frame
last trip: Arches and Capitol Reef National Parks
Name:	resize Arches nightfall.jpg
Old 11-06-2016, 09:40 AM   #13
I run one tank at a time, but truth be told since I bought a small space heater I never run my propane heater. The rare case being to get the camper quickly up to temperature then let the space heater maintain. The space heater has more than paid for itself in propane savings.
Kf4mnc is offline   Reply With Quote
Old 11-06-2016, 09:54 AM   #14
Never run out again. Just get a gauge for the tanks. This one is wireless.
zorky is offline   Reply With Quote
Old 11-06-2016, 11:39 AM   #15
GLCM Warrior
Lefty59's Avatar
If we're running the furnace overnight then for sure we have both bottles on, otherwise we may only have the one we are currently using on (we keep track by a placing a magnet on the in use bottle as an indicator).
Whenever we have both bottles on (and mostly even when we don't), I have a daily routine to check the switchover regulator for an indication that the bottle in use is empty. The indicator changes from green to red whenever the bottle in use (selected by the switch position) is empty.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 11-06-2016, 11:58 AM   #16
asquared's Avatar
We usually ran both on the old tt. The fiver we manually switch on our own. If you have an electric fireplace in your tt, you can use that for some heat. Most campgrounds also sell propane on site or can direct you to where you can get some. Worst case scenario go to a local grocery store or Wal-Mart and pick up a 20 lb grill propane bottle to get you through.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-06-2016, 12:13 PM   #17
...So, let's hear it. Do y'all run both bottles at once, or manually switch to the second when one runs out, and get the empty filled while running the second so that you've always got propane?...
I think you answered your own question.
Old 11-06-2016, 12:47 PM   #18
I used to run two and have run out of gas twice. I'm thinking of putting a small piece of clear plastic on my opaque tank covers to monitor the auto change over.
I now only run one. It's a lot easier to have something to switch over to than having to find someplace to refill the tanks.
I have also gone to a 1500w heater. It keeps the TT a comfortable temp. I save on propane and use the CG's electricity. I would guess 60% of my propane is used for HW, 20% refrigerator and 20% for cooking.
johng4706 is offline   Reply With Quote
Old 11-06-2016, 12:51 PM   #19
I run one at a time. This way I always have gas available as when I have to switch over, I make a note on our shopping list to get a tank filled. So I always try to have a full tank onboard.
I also use electric space heaters to supliment the furnace. And my Weber grill uses the small propane bottles so I always have something to cook with.
2012 Ram 2500 Crew Cab long bed B&W companion hitch
2015 Crusader Lite 30BH
2019 Harley Tri Glide
KB3FPI hammy
dinosaur is offline   Reply With Quote
Old 11-06-2016, 01:43 PM   #20
You don't unless you check your auto switch over indicator on occasion. If I'm in an environment where I know I'm going to be using high volumes of propane I check often. If just normal fridge or occasional hot water I check less. It does require some amount of vigilance but so do most things with an RV..
For me, it's both on and be vigilant abount checking the auto switch over valve indicator..
2016 Siverback 33IK, Towed 50K+ mile2018 Ford F-350 Lariat 6.7L V8 Diesel 4WD Crew Cab
