07-18-2021, 12:24 PM
Camp Stove High Pressure To Low
I would like to have my Campstove that uses a 1 lb. bottle work off my low pressure port off my trailer.
There are hose adapters available to convert the stove from 1lb. Bottle to a 20lb. But that is not what i want to do.
If you look at the pictures you will see that the inlet port to the stove is different than the Coleman stove.
There are lots of adapters available for the Coleman stove but not for my OUTBOUND stove.
07-18-2021, 12:52 PM
First thing, does your stove have a built in pressure regulator?
As you may not be aware of, most stoves or other peripheral propane items do do function well when directly connected to the RV low pressure line as they are being double regulated by their own regulator and the rv's. When this happens you will get a low flame issue.
The stoves specifically made to use on a RV low pressure port do not have a regulator built into them and are designed to work off the one from the RV.
2011 Flagstaff 831 RLBSS
07-18-2021, 01:07 PM
I see your regulator now in the last two pics.
07-18-2021, 01:10 PM
I know all that. Now if you look at the pictures the only regulator is the one that is on the stem that attaches to the 1lb. Bottle.
If you read my post again all i want to do is by pass the regulator. Or find an adapter that will directly allow me to use the port on my trailer.
07-18-2021, 01:14 PM
Yes its just like any other for the 1lb bottle.
The issue is the threads on the stove.
Just can't find an adapter to omit the regulator.
07-18-2021, 10:02 PM
You can try an email to propanegear.com. They were very knowledgeable and helpful when I had questions in the past.
07-18-2021, 10:19 PM
Thanks I never heard of them but I will try them out tomorrow.
Thankyou.
07-19-2021, 01:05 PM
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
07-19-2021, 01:12 PM
I don't know about your Outbound stove but SOME Coleman stoves work off high pressure only. That valve with a knob in your last two photos is NOT a regulator per se as in other LP appliances. Converting these stoves to work off low pressure is futile. You'll only get a tiny flame as the stove needs higher pressure and lots of flow.
This is not a grill folks. Just my 2¢ worth of experience with camp STOVES.
07-19-2021, 01:24 PM
Mini Lite 2109s (2019)
Low pressure stoves
My question why doesn't someone make a low pressure stove designed to be attached to a campers low pressure outlet?
07-19-2021, 01:41 PM
I have a Camp Chef that works wonderfully off the LP port. Just bought an inexpensive hose to replace the regulated hose that it came with.
My old pop up came with a Suburban stove that worked on LP. No mods needed.
There are multiple options.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
07-19-2021, 01:43 PM
There are some... but... there are some that are not.
07-19-2021, 02:47 PM
They do one came with my trailer! But what a piece of work that was!
Poorest quality.
07-19-2021, 02:49 PM
Originally Posted by MartyQ
I'm going to try them.
Thankyou.
07-19-2021, 02:50 PM
Could you post a picture of it?
07-19-2021, 02:53 PM
Sounds interesting if that's not a regulator, how do they regulate the high pressure so the stove works?
I know what your saying but I just don't understand how?
07-19-2021, 03:35 PM
According to the Outbound Parts Catalog the piping pictured with the CGA600 propane bottle connection above is a regulator for Outbound Dual Burner Stoves Models 076-5813-6 & 076-5809-8.
2016 Salem 27RKSS
07-19-2021, 06:03 PM
I am not condoning this in any way, but....
A friend of mine modified his coleman (roadtrip...I think) to work off his low pressure connection. He either spun off or cut off the regulator portion, cut off the (correct) end of a quick connect hose, and hose clamped it together. His justification was "its only 1# of pressure and I used 2 hose clamps...what could possibly happen". In his defense, it worked like a charm and has for over 5 seasons so far.
07-19-2021, 06:33 PM
Actually that is what I will probably do except I will make fittings to attach to the low pressure host to my trailer.
I have a lathe and it shouldn't be a big problem.
Thx
07-19-2021, 06:35 PM
I would be really grateful if you could send me link to the parts catalog. I have searched and searched but no luck.
