I may be repeating myself, posting is not there from first reply, Always treat alarms as real. Try a separate co alarm with 9volt battery to verify combination, also try turning off gas at valve at tank as leaks can develop in lines or connections even if appliances are not in use. You won't sleep in it until you find problem. Alarm companies have support lines. Look online for instructions to see if it can be cleaned or not
