I'm not familiar with the Suburban tankless, but the most important factor in most tankless water heaters is water flow rate. That's why you leave the cold water off and turn on the hot water valve 100%. If it's not warm enough, you turn down the valve to slow the flow rate, allowing the water to stay in the heater longer. But if you turn the flow rate down too much, it will turn off the burner. And if you open the cold water valve, you usually mess up the flow rate through the heater, causing the hot/cold cycling.
Our old tankless usually works great unless the incoming water temp is too warm, then the temp is too hot. So when at hookups, we open the bathroom sink hot water valve to a trickle while using our shower. The flow rate is increased though the heater and the water temp is cooler. And we don't have the temp cycling caused by opening the cold water valve.
If after experimenting with flow rates, you can't regulate the temp sufficiently, you might have an RV tech familiar with Suburban come and see if any sensors or such need adjusting.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
