Old 08-12-2018, 08:18 PM   #21
Splitshaft's Avatar
My new Forest River 2018 Sunseeker leaks like sieve, so I just use the range hood exhaust fan as it pulls lots of makeup air in all the gaps and air leaks in the coach. My range hood actually vents outside the coach unlike some more expensive coaches that do recirculate cooking fumes though a cheap carbon filter and back into the coach. Sometimes more money doesn’t always buy more functionality.
Splitshaft is offline   Reply With Quote
Old 08-12-2018, 09:05 PM   #22
Herschel
Puma26RLSS's Avatar
Do you crack open windows when cooking?
The gist of what I think I am reading is that unless the stove is burning a yellow flame instead of a healthy blue one, the stove is pretty much NOT a dangerous source of harmful gases (CO and CO2). But most Rv-ers either crack a window or use an external venting range hood fan combined with an open roof vent to keep a good circulation of air through the RV while cooking. This helps reduce humidity, reduce heat and odors, and clears out any trace CO or CO2 that may be generated. This may or may not assist the AC system at the same time. Thanks, guys!
Puma 26-RLSS travel trailer
27,000 miles towing, 61 weeks camping, 2010-2019
2007 Ram first ten years; 2020 F-150 Lariat >>>>
Puma26RLSS is offline   Reply With Quote
Old 08-12-2018, 10:07 PM   #23
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Curious
I couldn't resist.
I put my anemometer on the outside of the exhaust vent, with windows and doors shut I measured 3.8 m/s and with a window cracked 7.2 m/s air velocity (which is not volume).
Not a scientific test under lab conditions but close enough I guess.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 08-13-2018, 06:44 AM   #24
Global Nomad
Scheinin's Avatar
The same in my Cedar Creek. I just use the range hood that vents outside.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 08-13-2018, 06:52 AM   #25
"On the road again"
rjshiflet's Avatar
Been RVing for 17 years...never cracked a window when cooking, and as far as I know I'm not dead yet. On our last two fifth wheels we've never used the oven since they have convection/microwaves but we do use the stove top burners.
Like others have pointed out...these things are far from air-tight even with the windows not cracked.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 08-13-2018, 07:01 AM   #26
I just cook outside.
TheWolfPaq82 is offline   Reply With Quote
Old 08-13-2018, 07:05 AM   #27
BandJCarm's Avatar
No.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 08-13-2018, 09:31 AM   #28
Wolverine 1945's Avatar
Originally Posted by Puma26RLSS View Post
We are into our 8th year of RVing. 29 states on our camping map. We bought our 2008 TT used in 2010. The previous owner taught us to crack the window near the stove while cooking to add "ventilation". Sounded reasonable, so we have until recently. Decided the range hood ventilation fan external exhaust vent was essentially the same thing as a cracked window with a cracked open roof vent nearby for an "intake". Our Suburban manual does not mention ventilation at all in the safety section. Our "The RV-er's Bible" by Baker and Baker (1997) does instruct the RV-er to crack open a window when heating and cooking. I quote page 264: "Ventilation saves live. Crack the windows open a bit when heating the RV with propane or solid fuel or preparing meals."
What are other folks doing while cooking? What do you recommend?
Nothing works better that a Fantastic Fan !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-13-2018, 09:34 AM   #29
our roof fans are always opened, anyway, so we don't worry about it
The Turners...
formerFR is offline   Reply With Quote
Old 08-13-2018, 02:11 PM   #30
Filterman's Avatar
We crack the kitchen roof vent and turn on the hood fan. Takes the heat and gases off the stove to the great outdoors.
Filterman is offline   Reply With Quote
Old 08-14-2018, 08:02 AM   #31
Or you could just cook in the Great Outdoors !!!
Old 08-14-2018, 08:06 AM   #32
derek6669's Avatar
I do that too, trying to understand how it helps AC
derek6669 is offline   Reply With Quote
Old 08-14-2018, 08:16 AM   #33
Dark is Cool !!!
Old 08-15-2018, 06:27 AM   #34
Filterman's Avatar
We cook outside 90% of the time!
Old 08-16-2018, 07:04 PM   #35
Tiguan Tow r's Avatar
Other than using our microwave, all cooking is done outside on BBQ or toaster oven.
Tiguan Tow r is offline   Reply With Quote
Old 08-17-2018, 06:54 AM   #36
Definitely not camping if you are cooking inside,,, if the weather is nice !!!
Old 08-17-2018, 07:14 AM   #37
I cook outside if I possibly can. Don't want spatter and odor in such a small space. Generally have windows and vent open when I'm in the pod.
johnbryanpeters is offline   Reply With Quote
Old 08-17-2018, 07:42 AM   #38
Old 08-20-2018, 06:42 PM   #39
larry2c's Avatar
I find it sort of funny that the reason we open the window a bit and run the range hood has not been mentioned yet. If we don't run the fan and open the window a crack, we get the smoke alarm going off about half the time!
We do a lot of cooking on the Smokey Joe but beans and such go on the stove and it seems that the proximity of the smoke detector to the stove makes the darn thing go off even if there isn't any smoke (maybe just the heat?)
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 08-20-2018, 06:58 PM   #40
crack window
I don't like to steam up the place, so yes, I crack a window. I also turn on the fan. Almost always there is a breeze blowing, so i try to open a window on the windward side, with the fan running. that helps immensely.
If it is HOT or Freezing cold, I just don't crack it as wide.
2017 Puma Unleashed, 38 ft.
Dodge Ram 2017, 3500, Dually.
KG5TKV
Tiger Force Medic, 68/69
hankpac is offline   Reply With Quote
crack, window
