08-19-2018, 04:22 PM
#21
Put a remote temp sensor in the fridge so you can check temp without opening the door. It takes a long time (hour) to catch up every time the door is opened. It's not like a home fridge. The slide on that right fin is your temp adjuster (thermistor). Higher is colder. Make sure the wire end is near the top of the plastic sleeve then slide the sleeve up for Max cold.
2018 Forester 3011 DS
#22
Originally Posted by MR.M
Colder is always up on the fin not lower
Heaven is up... Hell is down!
Brian & Becky
2018 Avenger ATI 27RBS
08-19-2018, 04:37 PM
#23
Fridge facts
This type of fridge is actually an absorption fridge. The ammonia in the system is heated by an electric 120 volt (sometimes 120/12V) heater or a small propane flame.
These work really slowly but if the freezer is getting cold the fridge will too, it is the same refrigerant loop to cool both. If you load it with a bunch of warm food it could take a couple of days to get cold as it not only has to cool the fridge but the food too. Make sure everything you put in it is cold. We have put bottles of ice in the veggie trays to help cool things down and in really hot climates we will refreeze the bottles at night when the outside temps drop.
I use two fans on mine: A computer muffin fan on the outside coils with a thermostat that comes on at about 120 degrees to greatly increase the cooling efficiency and a small fan in the fridge compartment that runs on two D cell batteries to push the cold air in the bottom of the fridge back up to the top shelf. The thermostat for the whole fridge is on that slider on the cooling fins.
Also, it can take 30 minutes to cool the cold air lost from opening the door for more than a few seconds. If you have a group of fridge lookers - good luck, no fridge can keep up with that.
Hope this helps.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
08-19-2018, 05:04 PM
#24
Denver To Yuma In 90 Days
On Norcold refers the thermister works differently...and it took a long hard google search to find it!
On Norcold, you move the thermister to the left and down to make it colder.
However, in the Yuma, AZ heat where I live I couldn't move it far enough left or down to make it even luke warm in 110+ degrees.
Good thing I don't live in my 5'ver!
#25
Originally Posted by BeckyMax
Perhaps he bought privately, or inherited, or bought from someone who inherited. Not everyone gets a pdi and if not they have to research things in their own, which he/she is doing be asking on this board.
They bought a 2019 Wildwood so it's very likely new.
08-19-2018, 06:45 PM
#26
but the OP posted a dometic not a norcold
08-19-2018, 07:29 PM
#27
I know...
I was just mentioning it because I'm sure there are lots of Norcold fridges out there, and apparently they operate a little differently.
08-20-2018, 09:46 AM
#28
Keep the freezer as full as possible !!!
We pack ours as full as we can with Ice,,, leaving only enough room for our meat !!!
08-20-2018, 10:07 AM
#29
2011 Traverse LT, 3.6L, FWD
08-20-2018, 10:42 AM
#30
Originally Posted by rockfordroo
Nice System !!!
We just keep a small digital thermometer in both freezer & fridge !!!
08-20-2018, 01:32 PM
#31
That's really cool (no pun intended) and it's now on my "maybe some day list." Right now, I'm not willing to spend $24. If my freezer freezes water in an ice cube tray, my beer is cold in the fridge--I know it's working. The key is making sure that thermister (?) is as high up as it will go. It may slide down while on the road. If stuff starts freezing in the lower compartment, slide it down a little.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
08-27-2018, 06:13 PM
#32
fridge temp
This looks like my dometic. I had a similar problem in an older trailer and there is an orifice in the fridge burner that gets junked up. can be cleaned with acetone or finger nail polish remover, never a metallic object though
08-27-2018, 06:24 PM
#33
Got that one as well. Works great with no guessing and no door open / closey. 8 - 10 hrs will do it assuming food is prechilled. Freezer cools first. Mine cools a bit faster on LPG.
WW
08-27-2018, 07:23 PM
#34
Here are a couple things we have personally observed and although some things were mentioned in this post, I'll go into a bit more detail. Getting the trailer as level as possible makes a big difference. The manual for our fridge says the trailer only needs to be "comfortably" level. Our previous TT gave numbers 3 degrees side to side (relative to fridge) and 6 degrees front to back. We find that if you can get it within 1 degree in each direction (we use a digital level), our experience is that the fridge/freezer will cool down much quicker.
We also have one of these in the fridge and it seemed to cut the cool down time about in half for us. Some day we may put the coil cooler fans in but for now, we're good to go. Also, We have found (and I've seen plenty of others mention this) the fridge seems to cool down faster on propane than on electric so when I am getting our TT ready for a trip I switch from auto to gas. I'll switch back to auto when we get to the CG.
Regarding the PDI, we've bought 2 TT's brand new in the past 10 years and neither one was very good in my opinion and neither mentioned anything other than the Auto vs. Gas setting of the fridge. Should we have asked more questions, certainly - but when you don't know what to ask, what do you ask? And in some cases, the things I did ask didn't get answered well or even correctly. That's why I love the forums - lot's of smart people that have been there & done that to help you get good answers!
Hope this helped - and happy camping!
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
08-27-2018, 07:28 PM
#35
Is there suppose to be a tube attached? Mine lays in the tray
08-27-2018, 07:44 PM
#36
Does anyone see the thermistor in the op's picture? He needs to correct that before anything else.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
#37
I usually place a bowl of ice cubes in both the freezer and refrigerator when I power it up. This dramatically speeds up the cooling process. The freezer cools down so quickly that the cubes don't even melt. Forrest River Evo, std Dometic reefer.
08-27-2018, 08:21 PM
#38
Make sure your door isn't warped, even slightly, or the seal is secure. if the seal isn't making good contact all the way around, the cold air will keep leaking out. I've had it happen.
Also, take a mirror, and from the outside after removing the refrigerator hatch /door, look up and look for obstructions. I have seen insulation installed from the factory, fall over preventing the unit from venting properly.
Your fridge needs... level, heat and vent to work properly.
08-27-2018, 09:04 PM
#39
How I fixed my frig
I removed the freezer door. Took the gasket off the door and the Styrofoam out of the inside of the door. Reinstalled the freezer door. Freezer 17 degrees, frig 35 40 and I open it a lot.
08-27-2018, 09:15 PM
#40
How do you consider a 17 degree freezer fixed? I would replace the styrofoam and gasket.
