Old 03-23-2019, 05:23 PM   #1
Fairview propane regulator replacement
My auto switchover regulator is leaking past again. In other words I think both ports are open and feeding into the regulator no matter which way the valve is pointing (i.e. if I remove a line from one of the tanks there is still gas flowing through the disconnected line even though the valve is pointing to the connected tank). This is a standard Fairview auto-switchover type. This is the third one in four years I have to replaced in my 5th wheel. Does anyone have any suggestions for a better replacement?
pschweitzer is offline   Reply With Quote
Old 03-27-2019, 08:35 AM   #2
Old Enough to Know Better
gasman6674's Avatar
My suggestion would be invest in a quality regulator. Stay away from the "fairviews" and off brand china junk. You are going to pay a bit more but you will end up with a better unit. I work for a propane equipment distributor, but i don't want to get crossways of any forum guidelines by "selling" on the forum. So contact your local LP Gas dealer (ex Amerigas, Ferrellgas , Thompsons etc) and get a quality unit. Ps there are units with a ten year warranty availible.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-27-2019, 11:13 AM   #3
Head Rambler
If you want the best get a REGO 7525B. However, be prepared for sticker shock. They're about $200 a piece.
Gotta go campin!
irv, propane, replacement
