I have a 2014 Sandpiper bunkhouse, my furnace won't come on,and once in awhile I will turn it on and it will run for a cycle. Propane tanks are full. Where is the furnace on this 5th wheel?
You should be able to locate the furnace on the outside of your rig. It will have at least one exhaust port and maybe 2. Once you find it, on the outside that will direct you to where your access is on the inside of your rig. Hope you get it working soon. I recommend contacting a repair tech.
One port is intake for air to burn; one port is for exhaust (generally).
mine is under oven . look for a cover ,vented, 24x 12 aprox. remove front . slap top of heater with palm of hand a couple of times. a stuck sail switch is common. turn heater back on ,and let it run. FIXED MINE THAT WAY AND HAS NEVER BEEN A PROBLEM SINCE.
