The furnace is 12vdc powered so check the furnace fuse in your power center / breaker box / fuse panel. If the fuse is good check that your battery(ies) are fully charged.
You say when "Set fan to hi or low they come on", do you mean the furnace fan or air conditioner fan?
When you set the thermostat to auto and set it to heat do you hear the furnace blower start then clicking from the furnace a couple seconds later?
If you post the make / model of your furnace and either a picture of your thermostat or the thermostats make / model you will get help specific to that setup.
Richard & Jill
