12-27-2020, 09:36 PM
Furnace won’t relight
Hello. I have a 2005 Salem by forest river. I had the heat on and was working on the inside of the camper. The propane totally ran dry. I changed the propane tank. Now the furnace will not lite. The fan comes on and it clicks but it will not lite. The stove works so I know its getting propane. Please help
12-27-2020, 10:05 PM
Just as confused as you
Your furnace will try 3 times to light, if it fails it will go into lockout. To reset the furnace you need to turn off the thermostat then turn it back on. It may take up to 5 resets to get the furnace to stay lit.
If your thermostat has batteries in it you will have to remove them then put them back in to reset.
Richard & Jill
12-27-2020, 10:08 PM
What if my thermostat does not have batteries
12-27-2020, 10:12 PM
Seems like in the distant past I just turned the thermostat to OFF, then back to heat. But I could be wrong........
If all else fails, turn off the batteries, unplug the shore power (remove all power).
12-27-2020, 10:57 PM
Ok ill try that
12-28-2020, 12:12 PM
Did you not read my full reply?
In the first paragraph, I said to turn the thermostat to off then back on to reset.
Richard & Jill
12-28-2020, 12:29 PM
I did that.. I disconnected the propane and yhe batteries and un plugged it. After a few min I put it all back together. Turned it on .it fired up and then turned on and off a bunch of times making a loud hissing g noise.. now it seems like its ok.. do u think I had to get any air out of the lines
12-28-2020, 01:24 PM
That is why I said it can take several resets for the furnace to stay lit.
Richard & Jill
12-29-2020, 12:47 PM
With a 2005 tt, I would opt for replacing the lp regulator. They don't last forever, they're not real expensive and take about 15 min to replace. 11 '' ac or about .5 psi
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
12-29-2020, 12:58 PM
Thank you so much for ur help
12-29-2020, 01:07 PM
I hope you mean 11" wc (water column) which is 0.4 psi (0.397400210100894).
Richard & Jill
12-29-2020, 01:11 PM
Originally Posted by Scrapper
You mean 11" wc (water column) which is 0.4 psi (0.397400210100894).
Typo
14K Equalizer
12-29-2020, 01:44 PM
Typo
Your forgiven this time.
Just don't let it happen again.
Richard & Jill
