Old 12-01-2019, 04:10 PM   #1
2011 Berkshire 390BH
Furnace Won't Turn On Automatically
Howdy,
We have a 2011 FR Berkshire and live in the Pacific NW. We use our 'Berk all winter, either on short trips or as "surge housing" for when the kids are home from college, guests, etc. It's keep under a nice metal shed, with water, propane, and electric hook ups.
Recently (past week?) the furnace and/or thermostat won't hold a set temperature. It can be set at 65, but be freezing (almost) inside. If I turn the thermostat off and then back on, the furnace kicks in and bring the 'Berk up to temperature and then shuts off. However, it won't turn back on when the temperature drops. It will also turn on if I crank up the temperature (e.g., 70+), but with the same scenario: i.e., comes up to temp, shuts off, and then nothing.
Propane tank is full and I've tried a new full tank, but with the same results.
Any ideas???
Blessings, Dave
daverule is offline   Reply With Quote
Old 12-01-2019, 07:05 PM   #2
Howdy,
Any ideas???
Blessings, Dave
Old 12-01-2019, 07:29 PM   #3
Head Rambler
Which furnace do you have?
Which Thermostat do you have?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 12-01-2019, 07:30 PM   #4
Head Rambler
I posted in your other thread, Maybe the mods can merge or just delete this one.
Gotta go campin!
Old 12-02-2019, 01:48 PM   #5
Good morning Bama,
Here's a picture of the thermostat. I'm not sure of the furnace model. Where would I find it?
Blessings, Dave
http://www.forestriverforums.com/for...1&d=1575312474
Name:	RV Thermostat.jpg
Old 12-02-2019, 03:52 PM   #6
5 Button CCC Control
Originally Posted by daverule View Post
Good morning Bama,
Blessings, Dave
I know for a fact the 5 Button control never had any furnace associated problem.
almcguire is offline   Reply With Quote
Old 12-02-2019, 04:02 PM   #7
Head Rambler
Try resetting the thermostat.
System Reset
A. Turn the On/Off Switch to thee Off position.
B. Simultaneously press the Mode & Zone buttons while switching the On/Off Switch to On. FF should appear in the LCD display until the Mode & Zone buttons are released.
Gotta go campin!
Old 12-04-2019, 10:27 PM   #8
TimVWulp's Avatar
Suburban furnace control boards have been big poblem with failures you are describing. You need to replace the control board with a dinosaur brand control board that is bullet prof. $110.00 or less.
I have put a link to trouble shoot the furnace from the library at the top of this page. Trouble shooting starts on page 23. The trouble shooting section in the manual below is very good and will help you fix your furnace.
http://www.bdub.net/manuals/Suburban_Service_Manual.pdf
Hope this helps Tim
TimVWulp is offline   Reply With Quote
furnace
