Originally Posted by Twiet
2023 Rockwood 5th wheel. Furnace won't turn on. Not even blower. Fuses Ok. No breakers tripped. On shore power. Plenty of propane. Worked yesterday.
Cycle your thermostat OFF (wait 10 seconds) then ON. If that doesn't work, turn thermostat off, pull the fuse for the thermostat and/or furnace (wait 10 seconds) then put fuse back in & turn on thermostat to furnace.
Edit; It sounds like the furnace locked out due to ignition fault. It will try 3 times to ignite the propane. If it doesn't light, it will shut down & lock out. The above sequence should reset it.
2014 Prime Time Sanibel 3250
