Old 10-21-2019, 05:35 AM   #1
Gas Leak in our Dometic Stove
We were at Massey's Landing over the weekend and detected a slight gas odor from the stove area. I used a soap solution and think I see where it is coming from.... where the main comes into the stove top at the very first connection.
I assume it is over tightened or unseated somehow. Anyway, I plan to get a drop pressure tester and then confirm the leak; loosen and disconnect the fitting and then reseat it. Hopefully that's it.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 10-21-2019, 09:02 AM   #2
SeaDog's Avatar
If you got bubbles from the soap solutions no need to test farther try to snug the fitting first it may be just loose.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-21-2019, 09:27 AM   #3
An inexpensive gas/propane wand sniffer can be bought on Amazon. I find it to be easier to use and very accurate at locating leaks.
MtBiker is online now   Reply With Quote
Old 10-21-2019, 09:56 AM   #4
I agree. I am pretty confident that's where it is. My "field test" was with dawn soap and water drizzled on the connection and I did see some small bubbles underneath. Now that we are home I now have some uninterrupted time (not at a campground on Halloween with nieces and nephews and their kids swirling around me) so I can take my time and be deliberate and make sure what I saw is what I thought it was
Thanks for you note!
Marty
2016 F250 SD 6.2L
Old 10-21-2019, 09:57 AM   #5
Awesome! Thanks. I just bought one this morning at HD. It will now live in my camper!
Marty
2016 F250 SD 6.2L
Old 10-22-2019, 07:26 AM   #6
I fixed it. The leak was in the control connection "down stream" side. Disconnected the "upstream" fittings then removed the controller. Cleaned the threads and put thread tape used specifically for gas fittings. The fitting on the "down stream" side is not a compression fitting. Reconnected everything and turned on the propane. No leaks.
Marty
2016 F250 SD 6.2L
Old 10-30-2019, 11:23 AM   #7
By the way... I'm an idiot.
I don't have a Dometic stove....... It is a Suburban. Welcome to this small peek into my world.
Marty
2016 F250 SD 6.2L
dometic, gas, leak
