I do not know your model but can offer some advice. when you say a barbeque outlet i'm assuming it is a quick disconnect fitting. if it is then it almost certainly is low pressure propane that has already been through a regulator to reduce the pressure. the good thing is that this is the pressure you need to connect to an external bbq. do not install another regulator between the rv outlet and the bbq. you can get hoses with quick disconnect fitting already on them. you my need a couple adapters / fittings to connect to the bbq. there are many posts here on how to do it and many youtube videos on the subject.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
