Originally Posted by jimmoore13
A problem with NOT running the furnace. Condensation. Heat dries the air.
If you don't run the furnace, you should open some windows and your roof vents to allow water vapor to escape. Otherwise, human exhaust...exhaled breath and evaporation from your skin...can build up and condense out on the interior of the cabin. This is substantially worse when there is high humidity, it's raining, or it's very cold.
Just to nit pick. A furnace will not remove moisture from the air. Only an AC unit or a dehumidifier will do that. Hot air can hold more moisture that cold air, but the moisture will still be there. The RELATIVE humidity will appear lower. Most people incorrectly complain that running a furnace adds moisture to the air because the cold walls will condense quicker when the heat is on. Furnaces do not add moisture. As mentioned above they also do not remove it.
You are correct on needing ventilation is cold weather. Or we run a dehumidifier when ever we camp.
Jim M.
