04-15-2022, 04:08 PM
#21
Good to know my refill place may also recertify my cylinders. I'll ask next time.
-- Chuck
04-16-2022, 06:21 AM
#22
This thread has reminded me that on my old B van, there was a Tee in the black iron pipe coming from the propane tank. One outlet of this Tee pointed down towards the ground and had a 6" nipple with a cap screwed into it. It was meant to serve as a trap for this oil and although there were no instructions, probably for liability reasons, you could remove the cap or nipple and drain the oil. I remember doing it once and finding next to nothing, but I never used much propane in that van.
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
04-16-2022, 07:58 AM
#23
I had something similar on a natural gas water heater at home. The gas supply came down out of the ceiling and did a 90 into the thermostat. That 90 was a T with a pipe nipple on the bottom side. It might be useful to patch such a T into the propane line close to the tank on my trailer. But I never even heard of this problem until now. I don't know what benefit I'd get out of that preventative measure but I'm glad to know how to fix the issue if it ever occurs.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
04-16-2022, 10:36 AM
#24
What you are describing is often referred to as a "dirt leg" or "drip leg". It's a sediment trap that collects the stuff you don't want in your appliances.
All my gas appliances in houses I've owned had one just before the appliance connection rather than a regular 90.
Have never seen one on my TT's but if one has seen "Skunk Oil" in their lines adding one near the tank regulator might be a good idea.
I would imagine the quality control issues plaguing many industries now is also affecting propane production, transport, and dispensing.
04-16-2022, 10:48 AM
#25
Finding an oily substance is not new to propane systems. It's been around for years. Knowing the signs that it is effecting your system and how to deal with it is key.
I didn't know about a second grade of propane. Trust California to be unique..
https://www.propane101.com/propanegradesandquality.htm
Camped: 2023 (Days/Nights) - 34/27
2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
04-16-2022, 10:54 AM
#26
Interesting there are 3 grades. I'll try to remember if any grade is listed by my vendor. HD-10 propane appears to be a non issue in our campers.
However, HD 10 spec propane works just fine in domestic and commercial propane powered appliances. The primary problem that may be encountered in using HD-10 propane involves its use as an engine fuel (vehicles, forklifts, etc.).
-- Chuck
04-16-2022, 12:36 PM
#27
Example of a drip leg on my new water heater installation at my S&B home.
I can't easily put one in before the main RV regulator, but it can be done on the pipe out of the regulator. And the lower drip leg location would be protected by the front jack.
Now to decide if it is worth it
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-16-2022, 01:00 PM
#28
Well, someone at Winnebago thought it was enough of a problem to get it by the bean counters on my B. I don't have one on my Dynamax C and those guys love spending your money. I don't think I'll add one. Remembering that it might be an issue later down the road should be enough.
420 Ah batteries
400w Solar
04-16-2022, 02:38 PM
#29
The installer who replaced my 18 year old water heater in my garage -- looks darn identical to the one in the photo just posted -- told me the drip leg was "code." I don't recall if there was one there already but there is now and there's one on the furnace right next to the water heater too. And on the furnace for the 2d and 3d floors in the attic. I assume the cap is there to allow cleaning. I'll ask my furnace guy when he does my AC inspection in the next couple of weeks.
I was curious about the the little blinking light on the front of the water heater control since there's no electrical power to the water heater. Works by some magic electric principle of dissimilar temperatures or something I missed in 7th grade general science. Black Box principle: who cares why it works it just works.
-- Chuck
04-16-2022, 03:41 PM
#30
-- Chuck
A electrical current is produced via the thermopile making the LED flash.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
04-16-2022, 04:03 PM
#31
Ok, ya made me look up thermopile and learn something new
04-16-2022, 04:37 PM
#32
Kinda like the thermocouple keeps the gas valve open with millivolts produced by the heat of the flame.
420 Ah batteries
400w Solar
04-16-2022, 06:03 PM
#33
Like I wrote " magic electric principle."
-- Chuck
04-16-2022, 06:22 PM
#34
-- Chuck
It was "magic" back in medieval times. Today it's Science. Fewer animal parts involved
04-16-2022, 08:20 PM
#35
You could have provided a link to spare the rest of us from having to look it up, too.
04-16-2022, 08:23 PM
#36
Now I'll probably spend more energy just thinking about it than actually doing it.
04-16-2022, 09:06 PM
#37
I understand
04-18-2022, 06:29 PM
#38
How about installing a drip pockets at a convenient location just like near residential water heaters and furnaces etc....
04-18-2022, 06:30 PM
#39
How about installing drip pockets at a convenient location just like near residential water heaters and furnaces etc....
04-18-2022, 06:31 PM
#40
How about installing drip pockets at convenient locations just like near residential water heaters and furnaces etc....
